160* and bypass ok in the winter
Old Nov 28, 2003 | 07:33 PM
kudah440's Avatar
Question 160* and bypass ok in the winter
So many people recommends the throttle body coolant bypass mod, but is there a noticable detrament in the winter weather? Am I going to kick myself in the a$$ monday morning when I am fighting to get it warmed up like one of my carburated cars, or is it even a factor?
Also does any one run a 160* thermostat in the winter? Not extemely cold here in kansas, but 15-30 seems to be the usual morning temps. Any problems there either?
Since I have to bleed the coolant system tomorrow anyway am thinking about doing some cheap/free stuff.
Old Nov 28, 2003 | 07:36 PM
Heatmaker's Avatar
Advanced Member
Neither one of those mods are ideal for cold weather. I forgot why though maybe someone else could tell you.
Old Nov 28, 2003 | 07:37 PM
ibanez6rg's Avatar
The bypass will have nothing to do with your heat and the 160 will have little effect.
Old Nov 28, 2003 | 07:39 PM
drewstealth's Avatar
If it were that cold over there then i would just go ahead and use the 180* during the winter and the 160* stat during the summer. At those temps the car shouldn't run very hot anyways. But i'm can't tell you for sure since i don't live anywhere where the temps get that low.
Old Nov 28, 2003 | 11:18 PM
Shelldust's Avatar
Ive got 160* thermo and tb bypass and its usally about 20 here in the mornings, it takes it a lil while to warm up, but once it does its fine, id give it 5-10mins to warm up prob.
Old Nov 29, 2003 | 09:30 AM
The bypass won't hurt anything. I swap the 180 back in during the coldest months of the winter. I would say for Kansas winter weather, you would be happier with the 180.
Old Nov 29, 2003 | 10:40 AM
96b4ccamaro's Avatar
i have had the 160* and TB bypass for about a year and a half and never had a problem even when i go to upstate NY where it is like 5- 10* at night. It just takes longer to warm up.
Old Nov 30, 2003 | 06:01 AM
DOOM Master's Avatar
As long as you have your fans reprogrammed when you put in a 160 thermostat, you don't have to worry. Same on the TB bypass (which a number of people have already said), but of course there is no need to reprogram anything for that. The only time you might have a problem is if you don't reprogram your PCM, your fans will run constantly and you might end up running too cold. I drove my car around last winter with a 160 thermo (reprogrammed fan settings) and TB bypass, didn't have any problems. The only thing I noticed was it takes longer for the heater to get hot (so no FlyBono24, you aren't alone!). It gets down to -10F and lower here somtimes too.
Old Nov 30, 2003 | 06:05 AM
FuryZ28's Avatar
I live in KS and I've had a 160 thermostat & t/b coolant bypass on my LT1 Camaro for 5 years now, still runs great, and only problem is it takes a while for it to heat up & the heater doesn't blow as hot (probably because during the coldest periods, the temp doesn't go over 140-150... )
Old Nov 30, 2003 | 07:51 AM
kudah440's Avatar
Great stuff...so I guess Im up for the bypass today, and waiting for the 160*. Aside from slow heating up, my heater/a/c is not working anyway (only lighty blows from lower vents, and defrost) so I guess Im looking for vacuum leaks today also.)
Thanks for the input everyone
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
maverickmk
Sep 1, 2015 09:17 PM
