1500-1900 hesitation?
Old Apr 20, 2004 | 02:53 PM
ChickenScreamer94's Avatar
My car loses power, mildly hesitates, and just runs bad between 1.5k and 1.9k, especially at 1700-1800 or so. I have a new egr a few thousand ago (5K) and did IM leak fix at the same time. What is up? Many people said opit and wire, i also have a bad miss at about 1300 or so rpm, the whole car almost shakes in neutral doing it, and vibrates in gear on the road. I am thinking plugs, wires, and o2s, but i dont know fi that will fix it. MAF or something could do that?
Old Apr 20, 2004 | 02:55 PM
magius231's Avatar
could still be EGR. recheck the EGR valve and make sure its functioning, then check the EGR port on the intake and make sure its not plugged/clogged up.
Old Apr 20, 2004 | 05:39 PM
Bersaglieri's Avatar
I think there are about 75 people on this board who have or have had this problem. Let us know, cause I am going home tomorrow to work out a similar problem. Good luck, I am out of ideas on mine. But wires and plugs did not fix it.
-Dustin-
Old Apr 20, 2004 | 08:01 PM
nb 96 z's Avatar
try cleaning your sensors, especially the maf sensor. A lot of crap gets on it and can cause the symtoms you are describing.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
