15'' wheels on f-body
Old Dec 10, 2003 | 09:44 PM
95LT1TA's Avatar
Im wanting to buy some draglites 15x3.5 and 15x8's out of summit. My questions are do I need to grind the calipers? Do I need to buy longer studs? What backspacing do I need on all the wheels? Do I need to run spacers and how do I know what sizes to get. If I order these through summit , will they know what I need and do they sell all the parts. Anyone bought these from summit? Shipping charges?Thanks Mike
Old Dec 10, 2003 | 09:57 PM
RacinLT1's Avatar
summit has free shipping dont they? they wont know about the spacer deal,but they should sell them. longer front studs would be a smart idea,with the spacer it makes the threads a lil shallow.
as far as the wheels,15x3.2 get the smaller of the 2 listed b/s. the 15x8 is a 5.5" b/s,and i do believe you have to grind the caliper.
the spacers for the front can be bought at pepbpys etc and are 5/16" (if i remember correctly).
Old Dec 10, 2003 | 10:02 PM
97WS6SCharged's Avatar
You should only need to grind the calipers (not recommended) on a 98+ LS1 car. Or if you are using the LS1 brake conversion I would guess.
Old Dec 10, 2003 | 10:32 PM
LT1ponykilla's Avatar
I have 15'' Centerlines. I didnt have to grind on anything. I would get as much bs'ing as possible so your tires dont stick out to far.
Old Dec 10, 2003 | 11:03 PM
revtime's Avatar
You should be all right with 5.5 BS if you stick with a 15x8, a 15x10 on the other hand needs a 6.5 or even a 7.5 BS to tuck it under nicely. I have 15x10s with 5.5 BS and they stick out some but I like it that way.
I went with Weld Pro Star XPs because they don,t require any modifications to the calipers or any spacers.
They are heavier than regular Pro Stars.
Old Dec 11, 2003 | 11:55 AM
95LT1TA's Avatar
Yeah the XP'Sare alot mo $$$$$$. Does anyone have promblems with skinnies with there daily driver? Turns? Rain?
Old Dec 11, 2003 | 01:35 PM
SS MPSTR's Avatar
I wouldn't recommend skinnies for daily driving, but there will be a boatload of folks who disagree I'm sure.
Old Dec 11, 2003 | 02:42 PM
My95Z's Avatar
i have my hoosier slicks on 15x8 wheels from discount tire.. didn't have to do anything!
Old Dec 11, 2003 | 03:34 PM
ScottZ's Avatar
http://www.geocities.com/jmaxnakron/..._TELSTARS.html
Check out this link!!!
If you still want the Pro Stars, you will need WLD-96-58280 (15x8, 5.5"BS, 5x4.75" BP) Rear, and WLD-96-54270 (15x3.5", 1.75" BS, 5x4.75" BP) Front. YOU WILL NEED LUG NUTS. WLD-601-1412 (12x1.5 Shank Style 1.310" Closed End, 4 pack) Wheel spacers are 7/32" MRG-2370, 5/16" MRG-2371, and 7/16" MRG-2372.
Old Dec 11, 2003 | 05:33 PM
I have 15x6 up front and 15x8.5 in the rear. The front tires are plenty wide and handle good in turns. Im running 205/60/15's up front and 295/50/15's in the rear. They are skinny but not to bad. Nothing like a 3'' front rim.
Old Dec 11, 2003 | 06:01 PM
Kain's Avatar
I run 15" Telstars, didn't have to do any grinding or run spacers.
Unfortunatly, with Weld Drag Lites and Pro Stars, you'll need to run spacers, but shouldn't have to grind your calipers if you've got stock sized LT1 calipers.
Old Dec 13, 2003 | 05:02 AM
95LT1TA's Avatar
Will weld know what spacers I need with the draglites?
Old Dec 13, 2003 | 06:44 AM
RacinLT1's Avatar
no weld wont know. go to pepboys/autozone/etc and get 5/16" spacers.
Old Dec 13, 2003 | 11:05 AM
95LT1TA's Avatar
For the fronts or the backs? Longer studs?
Old Dec 13, 2003 | 11:59 AM
Cmr0z28's Avatar
Yep, they say the shippings free, but then they charge you for handling.....
