13's material mostly stock
Old Nov 16, 2003 | 10:04 PM
RickS's Avatar
i went to 7580 today, not hopin for mych better times than before, my old best was a 14.20 but i had this annoying sputter at around 4000rpms, i changed the oil, plugs, and put in some seafoam, and it seemed to really help.
i ran a
1/4 mi: 14.09 @95mph
2.20 60ft
1/8 mi:9.0913
i missed a shift at the last 200 feet, DOH,
and the whold time i was almost 1 car length from a car that ran a 13.1
the mods i have are a hooker catback and a K&N FIPK
shes got 92,000 miles
i know that it can run 13's
can someone disect my 1/4 and tell me what it might run
is my 9 second 1/8 quick? i not as firmilliar with 1/8 as the 1/4
Old Nov 16, 2003 | 10:09 PM
revtime's Avatar
Get your 60 foot a little better and you will run a 13.
Old Nov 16, 2003 | 10:12 PM
Heatmaker's Avatar
Advanced Member
What exactly is the "seafoam" thing?
Old Nov 16, 2003 | 10:25 PM
revtime's Avatar
Seafoam cleans the carbon out of your motor.
Some people use it and rave about it others have had problems with it.
If you do use it, take out the O2 sensors or buy new ones cause it will probably take them out.
Old Nov 16, 2003 | 10:46 PM
CamZ2811's Avatar
your mph is low something is up with that! you shuld be around 99 - 101. with the same mods I was running 13.90@102W/2.2060ft and thats with 118,000mi
The 410,s took me to what is posted in my sig.
sounds like your motor is getting tired time for spray!
-brian
Old Nov 16, 2003 | 11:04 PM
RickS's Avatar
well 75/80 was having problems with their mph thing today, my buddy ran a 13.9 in his transam ls1 @7.03mph
sorry i forgot to tell you all that
so my mph isnt correct. it was throwin all sorts of funny mph's today...
Old Nov 17, 2003 | 06:30 AM
stevil's Avatar
I ran a 13 second ET with a 2.2 sixty foot, looks alot like your run except for the MPH.
9.061 @ 80.50
13.963 @ 100.67
I've gotten many 2.0 sixties with street tires. Get yours down, and you'll run a 13.
Old Nov 17, 2003 | 12:48 PM
RickS's Avatar
actually the mph was off because i missed 5th gear, my mph traps would be around 101mph before
edit 4th gear
Old Nov 17, 2003 | 01:51 PM
b84camLT1's Avatar
5th gear! damn. what gears do you have?
Yea man, if you drop that 60' you'll be 13s. I kept pulling 2.4s and was running 13.7-13.9s then i finally cut a 2.1 and pulled a 13.5
Old Nov 17, 2003 | 01:58 PM
reuter's Avatar
if it gives you any idea what you should be running:
i ran a 13.9 @ 103.57 (2.37 60') in hot weather with nothing but a k&n fipk and 2OTL exhaust in my 95 m6 z28
Old Nov 17, 2003 | 03:21 PM
97bowtie's Avatar
RickS - What was you 1/8 mph? You sure it wasn't 4th gear you missed near the end of the track, not 5th?
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Collector Car
Jan 5, 2015 10:58 AM
CARiD
Dec 26, 2014 04:20 AM
LS1 RULZ
Aug 11, 2002 11:15 PM
