13's material mostly stock
i went to 7580 today, not hopin for mych better times than before, my old best was a 14.20 but i had this annoying sputter at around 4000rpms, i changed the oil, plugs, and put in some seafoam, and it seemed to really help.
i ran a
1/4 mi: 14.09 @95mph
2.20 60ft
1/8 mi:9.0913
i missed a shift at the last 200 feet, DOH,
and the whold time i was almost 1 car length from a car that ran a 13.1
the mods i have are a hooker catback and a K&N FIPK
shes got 92,000 miles
i know that it can run 13's
can someone disect my 1/4 and tell me what it might run
is my 9 second 1/8 quick? i not as firmilliar with 1/8 as the 1/4
i ran a
2.20 60ft
1/8 mi:9.0913
Seafoam cleans the carbon out of your motor.
Some people use it and rave about it others have had problems with it.
If you do use it, take out the O2 sensors or buy new ones cause it will probably take them out.
your mph is low something is up with that! you shuld be around 99 - 101. with the same mods I was running 13.90@102W/2.2060ft and thats with 118,000mi
The 410,s took me to what is posted in my sig.
sounds like your motor is getting tired time for spray!
-brian
-brian
well 75/80 was having problems with their mph thing today, my buddy ran a 13.9 in his transam ls1 @7.03mph
sorry i forgot to tell you all that
so my mph isnt correct. it was throwin all sorts of funny mph's today...
I ran a 13 second ET with a 2.2 sixty foot, looks alot like your run except for the MPH.
9.061 @ 80.50
13.963 @ 100.67
I've gotten many 2.0 sixties with street tires. Get yours down, and you'll run a 13.
9.061 @ 80.50
13.963 @ 100.67
edit 4th gear
Originally posted by RickS
actually the mph was off because i missed 5th gear, my mph traps would be around 101mph before
Yea man, if you drop that 60' you'll be 13s. I kept pulling 2.4s and was running 13.7-13.9s then i finally cut a 2.1 and pulled a 13.5
CARiD
Dec 26, 2014 04:20 AM
LS1 RULZ
Aug 11, 2002 11:15 PM
