12's possible?
Old Apr 23, 2009 | 02:10 PM
Sk8phreak88's Avatar
12's possible?
Hey guys I was wondering what you thought of my set up and what I'll run whn I get out to the track this year..
Mods are as follows:
Cam: 236/242 @.050 .555/.576-with rockers
Pro mag 1.6 SA roller rockers.
Ls7 lifters
Comp 918 beehive springs
Comp high tech hardened push rods.
SS ram air hood and intake with K&N filter
SLP mid tube headers
Flowmaster 3 inch from the headers back.
And soon a set of 4.10's in the rear end.
I'm really hoping to hit the 12 second barrier this year.. Think it's possible with yhat work done?
Old Apr 23, 2009 | 02:21 PM
Maverick_997's Avatar
12's should be easy to hit as long as its running right on the stock tune. with a tune i would say mid-low 12's @ 115-117 with traction IMO
Jeremy
Old Apr 23, 2009 | 02:24 PM
bombebomb's Avatar
12's easy.
Old Apr 23, 2009 | 02:28 PM
Wow that was quick! That's what I wanted to hear! Thanks guys.
Forgot to say I'll have a tune and a set of 315 D/R on the back to go with the new gears.
Old Apr 23, 2009 | 02:34 PM
JakeRobb's Avatar
Super Moderator
Good, I was going to come in here and say you weren't going to hit 12's without a decent tire.
Make sure to come back and post your results.
Old Apr 23, 2009 | 03:36 PM
reamo04's Avatar
with that cam, if you get ported heads i would say mid-low 11s would be possible w/o much hassle
Old Apr 23, 2009 | 09:26 PM
<Puck>'s Avatar
Stock heads, big cam, midtubes, and no suspension?
Low 13s or very high 12s. Add a dyno tune, full suspension, and ported heads/LTs and run 11s all day if you can drive .
Old Apr 23, 2009 | 09:45 PM
Rising Phoenix's Avatar
Sounds kind of like my current setup, although I do have LTs... see sig
edit: Also time in sig was done on bone stock 145k mile rusty/cruddy suspension, the only traction mod was Nitto drag radials on salad shooters
Old Apr 23, 2009 | 09:55 PM
The mid tubes were on re car when I bought it. long tubes and headers are on next years list if I don't upgrade to a vette or build a 6.2 for the car.
Suspension will be ordered next week hopefully. Well lca, pan hard bar, and sub frame conectors.
