124k + cam = bad idea?
Old Nov 23, 2004 | 01:08 PM
  #16
fastbird96's Avatar
Re: 124k + cam = bad idea?
I installed a hotcam at 130k miles and now have almost 150k with no problems. I've always ran mobil 1. When I had the engine apart it looked like new inside.
Old Nov 23, 2004 | 06:08 PM
  #17
billy mensch's Avatar
i had a 124k when i put my hotcam in and spun a rod bering within 10 miles
Old Nov 23, 2004 | 06:44 PM
  #18
romoranger's Avatar
do you ahve any information about the incident? what was it that actually caused the spun bearing? any diagnosis, or was it simply the cam?
Old Nov 23, 2004 | 09:42 PM
  #19
Myxtreme1's Avatar
It being the "cam" or something that happened from the cam install would be the same thing.
Old Nov 23, 2004 | 10:24 PM
  #20
Mystic97Z's Avatar
rebuilt mine at 130,000 new bearings everthing, used stock rods, broke one last week !!
Old Nov 24, 2004 | 08:48 PM
  #21
LT1 Bunny's Avatar
I'd love to install mine but it has 146,000 miles. But the oil pressure at idle when warm is slightly above 20....I think?? Car hasnt been cranked in a couple of weeks.
Old Nov 24, 2004 | 08:53 PM
  #22
faded93bird's Avatar
118 on the car when i did the swap, 11k later and MANY a 6.5k + pulls and still going strong.
I only drive my car to beat on it anymore, so it sees a lot of abuse.
I say do it
Faded
Old Nov 24, 2004 | 09:25 PM
  #23
ChrisUlrich's Avatar
People spin bearings because they rev way passed 5800 or 6k... my car will never see 6500.
Get a higher LSA cam and just call it a day. I'm at 116k almost and just replaced every damn thing in my valvetrain.
XE 227/233 Cam
Hardened Pushrods
Valve Springs
Comp R Lifters
Comp 1.6rr
Valve Seals and Gaskets
Timing Chain and Gear
I think thats it?
Old Nov 24, 2004 | 11:50 PM
  #24
Jameslt1TA's Avatar
i got 11500 on my ta and the engine is torn down to the short block. Well lets just say that the front cam bearing is TERRIBLE and all the cam bearings are gona get replaced. Im installing the cc 230/236 so i want to rev it to 6300 and dont want cam bearings going.
Old Nov 25, 2004 | 01:32 AM
  #25
TigerWoodsJr's Avatar
XE 227/233 Cam
Hardened Pushrods
Valve Springs
Comp R Lifters
Comp 1.6rr
I think thats it?
I rev mine, eeek. Not that bad really, I think im around 6 when I shift.
Old Dec 2, 2004 | 12:59 PM
  #26
"White Knight"'s Avatar
If you tore the block down to the shortblock and replaced the cam bearings....how would that increase your chances of not spinning a bearing? Or do you think you still might spin a main bearing??
armedtrigger
Feb 24, 2015 08:30 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Killer94z
Jan 13, 2015 12:06 PM
Noenav
Dec 6, 2014 07:35 PM
