12-bolt rear end
Old Oct 8, 2003 | 12:53 PM
z28marine's Avatar
12-bolt rear end
What is the "12 bolt" on a new rear end? What part of the rear end is being changed from 10 bolts to 12?
Old Oct 8, 2003 | 01:01 PM
turbo_Z's Avatar
its the size of the housing. our 10 bolts have a 7.5" ring gear where a 12 bolt which is much larger has an 8.75"?? ring gear. the larger the parts, the longer they will last and hold up to abuse. when guys talk about a 9", it has a 9" gear for comparison.. its also about the most heavy duty rear you can get for our cars.
Old Oct 8, 2003 | 01:06 PM
multicar's Avatar
Number of bolts that secure the ring gear, not the number of bolts on the access cover. Generally, the greater the number bolts, the larger the diameter of the ring gear.
Doug
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
