110LSA on 230/236?
Old Sep 18, 2003 | 02:12 PM
  #16
97Z-M6's Avatar
I have the 236 242 in my stroker. It is not good on the street. I drive two footed. My 1-2 shift is at 6200, ans 2-3 shift is at 6400 at the track. I do have CNC heads, 1.6 rr's, and longtubes...
236/242 is too much for the street
idling at 750-800, i sometimes stall coming out of park.
video of it in my sig. it chops hard!
thats in a stroker that tames it a ton, I have stock heads (not for long!) which quiet it and it sounds a lot less noisy in the video than in real life
you can also take that cam to 6900 rpms or so, so the power might be out of reach on stock bottom end.
the 230/236 should rev to around 6500.
Id personally reccomend a 232/234
now both these have hte cam. but notice neither would recomend it for a street car.
Old Sep 18, 2003 | 02:13 PM
  #17
97Z-M6's Avatar
Originally posted by NiteRider
Yeah, if you can find that thread that would be great. My friend dynoed hes 236/242 on a 112 and he toped of at 5900 @ 375 hp.
i will keep an eye out and look some more for it. but im at work right now.
Old Sep 18, 2003 | 02:15 PM
  #18
quicksilver97ta's Avatar
Originally posted by FacelessZ
What springs did you go with when you installed the XE 230/236?
Combination Motorsports, they are stock diameter and good to .600 lift.
Old Sep 18, 2003 | 02:19 PM
  #19
FacelessZ's Avatar
How would they compare to Comp dual 987's?
Old Sep 18, 2003 | 02:22 PM
  #20
I think they would have more spring pressure open and closed, but especially open. Those may be what Shawn has.
Old Sep 18, 2003 | 02:24 PM
  #21
FacelessZ's Avatar
so ?
Old Sep 18, 2003 | 02:35 PM
  #22
rskrause's Avatar
Moderator
I think it would probably make more hp than on a 112, but the power band will likely be narrower as well.
Rich Krause
Old Sep 18, 2003 | 02:38 PM
  #23
llafro's Avatar
I don't see how the 230/236 is mild compared to the 306? Are you just looking at the lift or what?
The 230/236 is mild compared to the 306 because of the reduced advertised (0.006" lift) duration.
Comp XE 230/236 w/ 33xx lobes:
230/236 @0.050" lift and 282/288 @ 0.006" lift
Comp "306"
230/244 @0.050" lift and 290/308 (I think) @0.006" lift.
So, the 230/236 crams similar lift and duration into a smaller amount of total duration. In fact, the 230/236 is only a couple of degrees bigger in total duration than a LT4 Hot cam.
Because the 306 cam has the valves open longer, it can make more power at high RPM, but at the expense of low RPM torque to some extent.
The 230/236 has much less overlap, so it will idle smoother.
Mine still sounds mean, but not quite like some others I have heard.
BRAD
Old Sep 18, 2003 | 03:10 PM
  #24
Brettinator's Avatar
Comp "306"
BRAD
Thanks Brad, that makes sense the way you explained it. Question for you on your mod list? You appear to have a stock bottom end and your running LT1 ported heads,cam, etc with a big 58mm TB? Wouldn't a 52mm be a better match for your setup performance wise? I can understand room for growth, stroker, bigger heads, etc but seems it would be too much causing a negative effect. Just curious?
Old Sep 18, 2003 | 03:17 PM
  #25
Kain's Avatar
I'm just echoing a few thoughts here.
I originally ordered a custom XE 230/236 with a 111 lobe (to have it lope like a monster). I was toying with a 110 lobe, but the Comp Cam guys said it would probably have to idle around 1000-1200 rpm.
Generally the lower lobe seperation, the shorter the power band. But for every 2 degrees it goes down (like 114 to 112), you gain about 10 foot pounds of torque.
Anyway, the cam ended up coming way late, and I threw in a CC306 instead, then sold the XE when it came.
Old Sep 18, 2003 | 04:46 PM
  #26
llafro's Avatar
I don't really know if there is any negative effect for me. From what I've seen, people do complain about the larger TB causing shift problems on an automatic. I haven't noticed anything untoward, but then I have an M6. I went with the 58 since it was the same price as the 52. I wanted to upgrade from the stock 48, so I just picked the bigger one. The car has outstanding throttle response, much better than stock.
Old Sep 18, 2003 | 05:26 PM
  #27
JohnsSS's Avatar
i put down 381 with a hotcam(112 lsa) at 6100....a 110 lsa moves the power band up aprox. 500 not 300...it is a significant difference
...and if ur engine is not built to handle 6600 rpm, something is gonna happen. stick with a 112 lsa.
Old Sep 18, 2003 | 09:20 PM
  #28
leadfoot94's Avatar
Ok, so most people say I should just stick to a 112LSA, what about the 111LSA? Seems like it would kinda be the best of both worlds? Anyone have experience?
Old Sep 18, 2003 | 09:23 PM
  #29
RealQuick's Avatar
With homeported heads and SLp shorties I made 351rwhp @ 5900rpm/348rwtq @ 4800rpm with the XE230/236 114LSA. I now have lloyd's heads/longtubes/TB/MAF/EW. I am expecting to turn around 6100rpm peak power.
Old Sep 18, 2003 | 10:17 PM
  #30
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I'm running the 230/236 on a 110lsa. Not sure what the lobe series is, but it has .598/.608 lift w/ 1.6 rockers. With the stock lifters and CMotorsport 608 <- I think?! valvesprings, I could only rev to 6000. Switched valvesprings to something pretty crazy <- around 150 on the seat while open (thanks again Seth! ) and a set of Comp R lifters. It'll rev to 6600 now, but falls off pretty sharp after that. I've been shifting at 6400rpms.
Even w/ this LSA, the cam still has plenty of low end pull ~ even w/ some "homeported" heads.
Check the graph if you need to . click me
