Is 11.54:1 compression too much on 93 octane?
Old Apr 7, 2005 | 06:47 PM
Pasky's Avatar
Finally got the heads cc'ed and 3 ports came out to 58 1/3cc and the rest were 58cc. If 11.54:1 is too much than i'll go with a 0.049 gasket and that should put it at 11.25:1 which i know it can handle.
The cam will be either a
230/244 .544/.574 112 LSA
or
234/242 .548/.558 110 LSA
Old Apr 7, 2005 | 07:20 PM
Pasky's Avatar
Re: Is 11.54:1 compression too much on 93 octane?
Could someone help me find the ABDC of these two cams so I can calculate my dynamic? Thanks.
Old Apr 7, 2005 | 07:36 PM
JONEZ_Z's Avatar
Im at 11.4 with 93 octane. Ive been running some octane booster just incase but i havent heard any pinging.
Old Apr 7, 2005 | 08:04 PM
disco192's Avatar
whats the intake centerline and advertised durations on those cams? You can get IVC times from that. Is this on the stock shortblock?
Old Apr 7, 2005 | 08:05 PM
Pasky's Avatar
I don't have a cam card for either =/. I just have the .50 duration and lift numbers. Stock block with .030 over and 3.750 crank.
Old Apr 7, 2005 | 08:24 PM
disco192's Avatar
the first cam is the cc306, you can find that info on comp's website
The other im not sure about.
Old Apr 7, 2005 | 08:27 PM
Pasky's Avatar
Already looked, only has the .50 duration in their online catalog.
Old Apr 7, 2005 | 08:30 PM
disco192's Avatar
if only i didnt lose that cam card... :doh:
You should be fine with 11.54 with that cam. I ran 11:1 in texas heat with that cam.
Old Apr 7, 2005 | 08:31 PM
Mindgame's Avatar
http://www.compcams.com/Technical/Se...umber=07-306-8
Thar she blows...
Fire up that DCR calculator.
-Mindgame
disco192's Avatar
what is your quench height? what kinda pistons are you running (cc of the dish/flattop?)?
Old Apr 7, 2005 | 08:33 PM
Pasky's Avatar
.039, -3.4cc
Old Apr 7, 2005 | 08:36 PM
Pasky's Avatar
I got 8.52 :1 with the cc306 and my setup with 11.54:1 compression ratio. Now what about the other cam. I don't have desktop dyno here so can't find the ABDC of that second cam.
Old Apr 27, 2005 | 12:20 AM
DevilsAddvocate's Avatar
What calculator are you guys using? I went to two websites. One asks for cam timing abdc (which is 55) and the other asks for cam timing abdc +15 degrees (which is 70) anybody?
Old Apr 27, 2005 | 12:51 AM
turbo_Z's Avatar
I got 8.46 DCR with the CC306 and cant seem to find any info on the other lobes. Either they are not Comp or Comp does not list them.
Old Apr 27, 2005 | 12:58 AM
Somebody wanna do mine?
11.41 static
4.155
6" Rod
3.8" stroke
cam abdc 55
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
