10psi oil pressure drop after 5k!
Old Aug 17, 2003 | 10:02 PM
Kreinmc's Avatar
The motor has nearly 155k very rough miles. I am using 20-50 motor oil. Is it possible something is getting clogged or is it just wear that is causing this. I never really paid that much attention to the oil pressure at wot, but i don't think that this should be happening.
Old Aug 17, 2003 | 10:30 PM
FastZinTennessee's Avatar
I have a problem where in second gear pulls the oil pressure will drop down to about 25 psi when I first get on it, then spike back up to 50-55 as the revs climp above 4250. No one seems to be able to give me a satisfactory answer as to why this is happening, so I continue to drive normally.
That's my advice- beat her into the ground!
John
Old Aug 17, 2003 | 10:35 PM
jasons93z's Avatar
why do you use 20-50? Just wondering.
Old Aug 17, 2003 | 10:37 PM
Kreinmc's Avatar
Too bump up the oil pressure a lil, the car has high milage, and it is hot as hell during he summer in Az.
Old Aug 17, 2003 | 11:00 PM
Re: 10psi oil pressure drop after 5k!
Probalby should not be happening (maybe not so unusual for the mileage), but the seriousness of it depends on where it is at when it drops 10 psi.
Old Aug 17, 2003 | 11:05 PM
94formulabz's Avatar
it drops 10 psi, or drops TO 10 psi?
You take it past 5k rpms and your not at WOT?
In every gear/ all speeds, or just off the line?
When is the last time you ran 30 or 40 weight oil?
btw, i don't understand whats not to understand about your dyno numbers so i guess i shouldn't be responding.....
Old Aug 17, 2003 | 11:21 PM
jasons93z's Avatar
Sounds like it drops 10psi(ie. 50-40psi)
Old Aug 17, 2003 | 11:27 PM
Kreinmc's Avatar
Re: Re: 10psi oil pressure drop after 5k!
The pressure is generally around 38-42 before it happens. 10 might be a bit exagerated, but it definately drops atleast 7 psi.
Old Aug 17, 2003 | 11:31 PM
Kreinmc's Avatar
I like to cruise on the freeway in second gear
Who knows maybe the 20-50 is too thick to flow very well at high rpms? My sig is like that for reason. There are quite a few little trolls on this bored that can't understand that my dyno was done before my cam even though it clearly said so in my sig.
Old Aug 17, 2003 | 11:39 PM
http://web.camaross.com/forums/showt...hlight=oil+pan
Well, this thread seemed like it might be relelvent to me.
I was also thinking maybe you should cut it back to 10-40 and see how it behaves.
I think it might have been shoebox who posted the rpm vs. tps to % WOT. Basically if i remember correctly if your high rpm you don't have to have it floored to be WOT. But that doesn't really affect your pressure, just that your WOT and you didn't realize it.
1loudz's Avatar
you're lucky man! mines drops 20-30 psi! it starts to drop just past 4K going from 40-45 psi, down to 20, then if i stay on it any longer it will sometimes drop down to 15. it once went down to 10 on a 116 degree day! its been doing this for 2 years, ive posted on here multiple times about this problem, and got plenty of answers. i guess my oil pump is just worn out, and cant keep up at that high of RPM's. as the other guy said, ive simply put in the back of my head, hoping to forget, and praying nothing goes till i have money for a new engine. i cant really think of nething else to do. if i go in there to try to replace my pump, i might as well rebuild the bottom end, so ill just put it off i guess.
i use 5W30/10W30 mobil 1 and an extra capacity filter and have 103,000 miles
-Ryan
Old Aug 18, 2003 | 01:06 AM
mycarisfasterthanyours's Avatar
As long as it doesn't go knock, knock, knock I say drive away, but then again I doubt I am the one to be listening to right now. BTW, If it does go, I can definetely recommend a machine shop not to take it to.
Old Aug 18, 2003 | 01:55 AM
Zeueses 97 RamAir's Avatar
oil change
change your oil 10w 30 synthetic
Old Aug 18, 2003 | 02:33 AM
Est96Z28's Avatar
I do use also 20w-50 synthetic oil and have no problems with pressure drop at higher rpm's.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
