106 Octane Fuel. Safe?
Old Mar 2, 2003 | 02:48 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by Mindgame
And sometimes you actually slow down with the higher octane fuel. I think alot of it has to do with having the "right" burn rate and the higher octane stuff just burns a bit slower (less volatile).
What we used to do is get about 5 gallons of 92-93 octane in the tank and take 2, 5 gallon containers of 108 with us. Make a run and get your mph (ET don't count here). Then run the car with 3 gallons of the 108 added. If the car picks up mph then you're headed in the right direction. Keep adding 3 gallons of 108 until you slow down or stagnate. Mind you that you need to keep everything very consistent from one run til the next... same coolant temps, everything as close as possible.
Of course we do this on carb motors where we'd also advance the timing. So there are some other things that play into the process but it does give you an indication of what octane the engine really wants. Sometimes the lower octane stuff burns at just the right speed for a given advance. I'm not sure of a way to determine the actual octane increase with this method though. Anyone know??
-Mindgame
ahh the world of tuning
where trey gets flustered and crys
Old Mar 2, 2003 | 03:31 PM
  #17
12sec97Z28's Avatar
Won't leaded fuel screw up your injectors too?
Old Mar 3, 2003 | 12:21 AM
  #18
No.
KYWes
Sep 26, 2015 08:49 AM
rideordie
Sep 7, 2015 08:22 AM
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
Anon
Jul 23, 2015 12:18 PM
