"10273" casting number on block?
Old May 23, 2007 | 09:39 PM
tfalconier's Avatar
anybody know what casting number this Lt1 is? it looks like the casting number on ends with "10273" and it looks like it says 5.7, but also 637 anybody know what it is?
Old May 23, 2007 | 10:14 PM
Where are you finding this?
Old May 24, 2007 | 06:23 AM
tfalconier's Avatar
right by the oil filter on the block, i cant make out the rest of the numbers, the ps pump has a connector in the back so i think it may be an impala ss or 9c1 motor, just want to make sure its not a 4.3, anybody know where it says 4.3 stamped on the motor?
Old May 24, 2007 | 06:32 AM
tfalconier's Avatar
it says vo122ysx on the pad in front of the cyl head too
Old May 24, 2007 | 07:00 AM
That is not a casting number. It is a VIN derivative stamped on the block.
All LT1s have 327 cast into all sides of the block. L99s have 4.3 cast in the same areas.
Old May 24, 2007 | 04:25 PM
tfalconier's Avatar
Are Impala, and fbody engine brackets the same?
hey guys, im just wondering if the impala and fbody brackets are the same, for some reason my 96 ws6 has an impala ss ps pump in it, and the factory one doesnt look like it bolts to the bracket, but on that same bracket the "cover" piece unbolts, i was wondering if this is the only diffrence, or if the bracket itself is diffrent
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
ModdedNerd
Jan 29, 2015 07:23 PM
