1 stage colder plugs or stock?
Old Apr 3, 2004 | 07:49 PM
besz28's Avatar
i finished my heads and cam install along with 30 lb injectors etc.... i used tr6 plugs one stage cooler, my mechanic said go back to the stock heat range,so i put in the tr55.should i run 1 stage colder plugs with heads and cam? or was he right? he said only for nitros do you need to do colder plugs. thank you
Old Apr 3, 2004 | 07:54 PM
Max 93's Avatar
pretty sure you only need to use colder plugs if you are using nitrous or raise the compression
Old Apr 3, 2004 | 08:00 PM
gb95zconv's Avatar
Stick with the tr55s....your mechanic is correct.
Old Apr 3, 2004 | 08:05 PM
LPE Z convt's Avatar
You should drop one heat range for every 75-100 horsepower added to the car... TR-6 s are only a half heat range colder than stock.... People get buy with running stock heat range plugs with your setup but too much heat will mean trouble later on....
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
importkiller94
Jan 17, 2015 09:03 PM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
