1 out of 10 times ECU fails?
Old Jun 12, 2005 | 11:50 AM
ChvyCruzen's Avatar
I heard that while reprogramming an ECU, it is possible that 1 out of 10 times the ECU will fail and crash, then will be no good.
What is the cause of this? Is it the PC locking up while uploading data or the ECU just doesnt like it?
I have reprogrammed my ECU a few times but before I do anymore I would like some feedback about this.
Old Jun 12, 2005 | 11:57 AM
madwolf's Avatar
Re: 1 out of 10 times ECU fails?
It depends on a number of things. Noise in the electrical system, bad grounds, low car battery, low laptop battery, poor connection, other programs/devices interfering/interrupting the upload process on the laptop, human error, etc.
The reason the PCM does not work after a failed upload is because the program completely erases a chip at a time (out of 2 total) and then reprograms it. So if a reprogram halts during reprogramming, you've got a bad program and the pcm will not allow the car to start. In addition, you cannot just overwrite the corrupted program because the flash is corrupt and the chip cannot initialize itself to "talk" again.
These PCMs can be repaired though (I offer this service).
For what it's worth, I've reflashed mine on the road about 26 times a couple of weekends ago and had no problems, but even though I can fix them, I'm still nervous.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
