1 Last T.B. Bypass Question on a '94...
Old Oct 18, 2006 | 12:05 AM
SevenStars's Avatar
So I know that on a '94 you need to buy a barb and connect the 2 hoses that originally went to the throttle body.
I had to get a new upper radiator hose and it doesnt have the provisions for the TB bypass (plus it looks cleaner) and I'm usng the radiator out of a '96...
So would it be ok just to plug the inlet on the heater line and run it as is or do I need something else? Also what should I use to plug it? Would a 3/8ths vacume cap and hose clamp work?
Thanks,
Stephen
Old Oct 19, 2006 | 08:57 AM
SevenStars's Avatar
Re: 1 Last T.B. Bypass Question on a '94...
Any one?
Old Oct 19, 2006 | 09:35 AM
OBE1 95Z28's Avatar
Thanks,
Stephen
The line running along the passenger's side valve cover is not a heater line; it's a line coming from the back of the heads that's necessary to relieve air that might develop in the heads from steam. Don't cap off this line.
Old Oct 19, 2006 | 09:58 AM
SevenStars's Avatar
Oh, no I was talking about the outlet on the heater line next to the coolant bleeder screw... It isnt present on the 95's and up but is on the 94's...
I thought on the 94's you connected the coolant bypass hose (on the upper radiator hose) to the outlet next to the bleeder screw (passenger side), but I dont have the bypass provisions on my hose anymore so can I just plug that outlet and with what can I plug it with that wont go out on me?
Old Oct 19, 2006 | 01:10 PM
Mtrhds94Z's Avatar
I thimk I know what you mean..
You replaced the 94 radiator hose with a 95-7 hose [with no funny 'wye' in it] and now have a hose going to the 'bleeder pipe' that you need to get rid of..
To use 95-7 configuration on 93-4 you need a 'heater outlet hose
connector'[bleeder pipe] without the 'tee' on it, that the 93-4 one has
[The 95-7 one doesn't have a tee] it is GM p/n 10262478
You just cut off the swaged clamps, and then use reg hose clamps on both ends..
The above would be the correct way to do it.. I guess you can just cap it off also, but be sure it's a good sturdy cap..
Old Oct 19, 2006 | 02:22 PM
A vacuum cap would probably pop like bubble gum.
Old Oct 19, 2006 | 07:55 PM
SevenStars's Avatar
I need to get this on the road asap so what wouldent pop like bubble gum?
Old Oct 19, 2006 | 10:13 PM
Mtrhds94Z's Avatar
[the correct hard pipe I posted above would be best]
For now I guess you could put a short length of hose[a piece of the bypass hose you removed] on it with a clamp, then plug the end with a bolt etc that fits tight[and isn't threaded all the way up to the head] then clamp that.. that should hold..
Old Oct 20, 2006 | 09:17 AM
SevenStars's Avatar
Thanks, I plan on doing it correctly but am moving to NY in 2 weeks and I need to have the car running, broken in and tuned by them.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
lbrowne
Nov 13, 2011 04:25 PM
RedLineRev
Jan 23, 2003 03:51 PM
