1 fog light turned off?
It's a bulb, I'm sure. It's a pain in the butt to change too. You have to pull half the bumper off, that's an overstatement, but it still wasn't fun. The bulb is like 6-7$ at any parts store. Have fun
They are a pain to change, I put some aftermarket ones on just for that reason.
You can snake your arm in there with some of the lower push clips removed but you will be working blind the whole time.
Good Luck.
Good Luck.
I have a 96 Z and just replaced the passenger side fog lamp the other day and it took me almost an hour and a half...however i could do it now in 1 min. Jack the front of the car up enough to lay under and look for the wire going to the bulb from the engine bay area...follow that with your hand and with some bending of the arm you can reach all the way to the bulb. I kept reading how hard it was and at first was going to do it from the front, but when i got my hand up there i realized how easy it was, the other side is the same way.
Bill
Bill
Brake_L8
Jan 20, 2015 09:44 AM
