#1 cylinder misfiring? All headers are HOT but i can HOLD header for cylinder #1
Old Oct 27, 2003 | 09:59 PM
  #16
Robert95z's Avatar
If it is a faulty injector, how can i clean it out myself?
-Robert
Old Oct 27, 2003 | 10:37 PM
  #17
Fullagar's Avatar
it sounds to me that the plug isnt firing, you said that it looks fouled and that when you grounded the plug to check it didnt look like it was firing. i suggest you pull the whole wire and look it over, might have chafed somehwere and be grounding out, or you can try to have someone start the car while its dark and look under the hood for arching (had this problem in my '93, turnedout that the plug wire had burnt on the manifold) just anohter thing to try before you pull the fuel rails.
Fullagar
Old Oct 27, 2003 | 11:35 PM
  #18
Robert95z's Avatar
Fullagar, im not sure what u r talking about, but anyways...
#1 looks fouled right? Well i looked at #5 plug and it looked 10x better! I then did a spark test using the fouled plug using the #1 wire on the opti and it got good spark...
So i took off the fuel rail and took a look at the injector, it didnt look extremely dirty, dunno if its stuck open? stuck closed?
Autzone sells them for $70/each (ouch! )
Guess i'll buy an injector
-Robert
Old Oct 28, 2003 | 12:04 AM
  #19
LilJayV10's Avatar
Have you run a compression test? I know it was asked earlier but I never saw an answer.
Old Oct 28, 2003 | 12:08 AM
  #20
Robert95z's Avatar
No i have not, because..
A. do not have a compression gauge
B. really, really, REALLY do not want to take out all the plugs
Old Oct 28, 2003 | 07:48 AM
  #21
bad79z28's Avatar
You can do a compression test on just that one cylinder...since that one is the only one that is missing.
Old Oct 28, 2003 | 08:00 AM
  #22
sikz28's Avatar
why don't you try swapping parts (injectors, plugs, wires) one at a time from one cyl to the next and see if the misfire changes cyl's. as soon as you move whatever is causing the problem to another cyl the miss should move with it.
Old Oct 28, 2003 | 08:46 AM
  #23
kmook's Avatar
Advanced Tech Moderator
It most likely is opti or the injector.
You said you tested the spark from the #1 wire correct and it was good? Well then i'd go to the injector next.
Why not swap injectors and test it real quick. Swap say 1 and 7 and see if the problem follows the injector....
Old Oct 28, 2003 | 09:20 AM
  #24
Robert95z's Avatar
I'll swap the injectors when I get home from work today (6pm cst) and i'll let you guys know what happens.
-Robert
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jul 4, 2005 05:00 PM
