#1 and #8 cylinders misfiring, why???
Old May 10, 2004 | 01:14 PM
john97z28's Avatar
Angry #1 and #8 cylinders misfiring, why???
2 weeks ago my neighbor and I installed Jet-Hot LT’s, Hooker Y-pipe, and Taylor OTVC wires, new spark plugs, new O2 sensors, removed the EGR and Air pump, and did a OBD-I conversion. We took the car for a test ride and it car wasn’t running as it should. This past weekend we hooked the car up to my friend’s scanner and no codes were coming up. I put my OBD-II PCM back in (for scanning purposes) and it showed that cylinders #1 and #8 are misfiring. My friend had an extra set of wires in his garage and we swapped them in and it was still misfiring. I have checked for burnt wires, sensors, etc and can’t find anything wrong. Could it be an injector, vacuum, ect? Does anyone know what might be wrong? I was trying to figure out what the relationship is between #1 and #8 compared to the other cylinders. Why are they singled out and it’s not a widespread problem throughout the others. Maybe that will help narrow the problems down. Any help would be greatly appreciated.
Old May 10, 2004 | 01:16 PM
turbo_Z's Avatar
try replacing those spark plugs.
Old May 10, 2004 | 01:19 PM
john97z28's Avatar
New ones were installed, all Autolight 104's gapped to .040. They are brand new. I could try it though.
Old May 10, 2004 | 03:23 PM
Red95M6Z28's Avatar
I am not a mechanic but couldnt the optispark be bad causing the cylinders to not be getting spark at the right time?
Old May 10, 2004 | 03:34 PM
john97z28's Avatar
When the opti goes bad, is it seen thoughout all the cylinders or can it affect 1 or 2 like in my case. The car has 53,000 miles on it.
Old May 10, 2004 | 03:41 PM
turbo_Z's Avatar
from what I have seen on here the opti can drop a cylinder or an entire bank.. just depends on what breaks i guess.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
