1.7 rrs and the lt1
Old Feb 26, 2008 | 10:28 PM
Ironxcross's Avatar
1.7 rrs and the lt1
are they too aggressive for the valvetrain? what's the major issue that everyone seems to run into with them? do other companies rockers fit into the lt1 head if they have the same stud size? (ex. ford)
Old Feb 26, 2008 | 11:00 PM
DelSoto's Avatar
throws the geometry off too much....don't do it
Old Feb 26, 2008 | 11:18 PM
LSWHO's Avatar
why not get rockers made for the sbc? Scorpion makes 1.7s for the lt1
Old Feb 26, 2008 | 11:28 PM
ss.slp.ls1's Avatar
Why not just go with the tried and the true...cc 1.6 rr's.
Old Feb 27, 2008 | 09:19 AM
96m6lt1's Avatar
i dont beleive this statement to be true at all,when you place this 1.7 roller on the stud and measure it,it is alsmost dead center with eachother(valve tip to rocker tip)
the biggest deal with the set up is modding the valve covers or getting taller ones,getting new valve springs etc. If you can't instal a cam this is a good way to go! besides Lt1s like more valve lift and don't need a bunch of duration.
Old Feb 27, 2008 | 02:07 PM
Ironxcross's Avatar
Now where would I go about finding these good valve covers...
Old Feb 27, 2008 | 05:53 PM
Gtpguy's Avatar
You can modify the ones you have. You just have to cut some of the supports and you are good to go. I'm sure someone has pics on here somewhere.
Old Feb 27, 2008 | 06:01 PM
PWR SHFT's Avatar
Who sells them?
Old Feb 27, 2008 | 06:27 PM
96m6lt1's Avatar
www.flatlanderracing.com part#scp1026 1.7rr
Old Feb 27, 2008 | 06:33 PM
dangalla's Avatar
http://www.golenengineservice.com/ht...html#valvecmod
i would just stick with the 1.6 rockers though
Old Feb 27, 2008 | 06:38 PM
white97T/A's Avatar
They would be too aggressive for the stock springs.
Look up Comp Cams, Crane Cams, GM Performance Parts, etc. all these companies offer rocker for the SBC, I would not recommend trying to find Ford rockers that could work on your motor. BTW stock the rocker studs are 3/8" on top and 7/16" threaded into the head, but you can upgrade your studs to 7/16" top and bottom. - which would require the matching rocker arms.
Old Feb 27, 2008 | 07:02 PM
PWR SHFT's Avatar
I would have to convert to guide plates to use these. I think I will stick with the 1.6's I already have.
Old Feb 27, 2008 | 11:46 PM
96m6lt1's Avatar
Whats the big deal with changing to guide plates,go to 7/16 studs instead of the 3/8 studs and have hardened pushrods with 1.6 or 1.7.....3/8 studs flex too much at higher rpms
Old Feb 28, 2008 | 08:57 AM
PWR SHFT's Avatar
Budget is too tight. But I will keep it in mind for later.
Old Feb 28, 2008 | 09:11 AM
96m6lt1's Avatar
i see,well it's like that over here too! i have sold off most of my stereo equip.to buy more go fast stuff. good luck bro..
