1.7 rockers with stock cam
Old Dec 13, 2007 | 01:52 PM
Daniel6718's Avatar
not sure where to put this but does anyone have a sound slip of idle with it? im wanting to make some good bolt on power but not wanting to sacarfice idle sound and the car shaking ect...
and id like the surprise aspect
Old Dec 13, 2007 | 02:15 PM
96m6lt1's Avatar
stock cam along with 1.7 rockers will not be noticeable in an audible situation.
Old Dec 13, 2007 | 02:19 PM
rich152's Avatar
1.7 rockers on a stock cam and springs are a very bad Idea.
Old Dec 13, 2007 | 02:50 PM
Daniel6718's Avatar
read my sig...im aware my springs wont cut it...thinking maybe i can make more than 315 with bolt ons
Old Dec 13, 2007 | 04:27 PM
MeanGreen97Z's Avatar
You put some LT4 springs on there yet? I'm sure you will get some power out of it without being able to hear it in the exhaust.
Old Dec 13, 2007 | 09:05 PM
Daniel6718's Avatar
no springs yet...might look for a set but crane 10308 i had great luck from and they are cheap new and they are doubles...
i was searching and couldent find they will fit under stock valve covers right?
finally is scorpians(sp) the only 1.7 you can use?
Old Dec 13, 2007 | 09:14 PM
Stoopalini's Avatar
1.7s will not change the sound of the car at all, and they will not fit under stock valvecovers.
I'm using the Comp 26918 beehive springs. I bought mine before the quality control issue, and haven't had any issues with them.
For a complete, detailed write up of installing 1.7 Scorpion rockers on a stock motor, read this thread
Let me know if you have any questions,
Thomas.
Old Dec 14, 2007 | 02:55 AM
slomarao's Avatar
lt4 springs wont be enough to handle 1.7rr's. look at something stronger.
Old Dec 14, 2007 | 04:34 AM
rskrause's Avatar
Moderator
I dunno for sure, but I suspect there may be some problem with pushrod interference and 1.7's. If you get them, check carefully.
Rich
Old Dec 14, 2007 | 08:02 AM
Stoopalini's Avatar
When I installed the 1.7s with 7.150 pushrods and GMPP guideplates, they bottomed out on the guideplate on full valve seat. As you can imagine, the setup was extrememly noisy!
I ended up lengthening the pushrod slot in each guide by about 1/8" for added clearance.
I haven't noticed any other interference issues and have been running them for almost 2 years and 23k miles now. The pushrods do come pretty close to the head casting, but they do clear. Not sure if casting variances would be enough to allow contact, definitely something to check when installing.
Thomas.
Old Dec 14, 2007 | 08:06 AM
Daniel6718's Avatar
they wont clear sotck valve covers?
i knew id have to check pushrod leingth...and heard some stuff about geometry so i was going too check that, and ive got a 95 so i wanted to get hardened pushrods anyways...
and yes rockers can change a cars sound...have you heard a zo6 with aftermarket rockers
Old Dec 14, 2007 | 08:16 AM
Stoopalini's Avatar
No, they won't clear
I had to use a different length pushrod to get the geometry correct. I would recommend chromoly rods over the hardened. You definitely do not want any deflection in the pushrod with a 1.7 setup, as the fit is very tight.
Ummmm, ok ..... but this is not a zo6, it's an LT1; and I have the 1.7s installed in my car with a stock cam, and it did not change the sound.
Thomas.
Old Dec 14, 2007 | 08:49 AM
Daniel6718's Avatar
well i read your thread...ive hear rockers change a lope i mean think your changing the cam size....but thats what i wanted to hear that it still sounds the same
i read your thread and some1 posted a list of what they used on the install and didnt post getting valve covers...im goana do a little more research on that...i didnt think lt4 gave you any more clearence than stock, and id really like to not have to buy some valve covers...that would kill the budget, although they do look nice and id like to have some
and ill probably do that for pushrods...love buying chromoly stuff anyways...
Old Dec 14, 2007 | 09:04 AM
Stoopalini's Avatar
The rockers change the lift, but do not change the duration. I didn't notice anything different about the exhaust sound after installing.
You may be able to clearance the stock covers to fit, not sure on that because I decided early on to go with the LT4 covers for 2 reasons: no need to modify them and also because the material they are made from absorbs the roller rocker noise better than the stamped steel of the stock covers.
The LT4s definitely give you more clearance than stock.
As for budget, this is not a cheap mod to do. Off the top of my head, you'll need:
  • Rockers
  • Springs
  • Locks
  • Retainers
  • Guideplates
  • Pushrods
  • Valvecovers (or mod the stock ones)
  • Lifters (maybe)
  • Rocker Studs (stock is 3/8" ... you'll need 7/16")
  • Oil, gaskets, etc ...
If you're working on a tight budget, I'd recommend 1.6 self-aligning rockers over the 1.7s. I probably spend somewhere around $1k on this Of course, that included the LT4 covers + hardware and a new set of lifters (which you already know after reading my thread)
Thomas.
Old Dec 14, 2007 | 10:05 AM
ChevalierSS's Avatar
changing RR ratio isn't going to change the sound of any cam. The sound people typically like to hear is the "lope". Lope is a function of lobe seperation angle on the cam. RR can't change the LSA.
