1.6rr's on stock springs?
Old Feb 14, 2008 | 02:29 PM
96supersport's Avatar
can it be done? i guess the real question is should it be done?
Old Feb 14, 2008 | 02:34 PM
Javier97Z28's Avatar
Moderator
Not the best of ideas, but yes, it's been done.
You could get a set of LT4 springs.. they're pretty cheap and up to the job.
Old Feb 14, 2008 | 02:50 PM
Can it? Yes.
Would I do it? No.
Old Feb 14, 2008 | 04:56 PM
BUBBA's Avatar
Stock springs are marginal as it is. Wonder why you run out of wind on top? I'd guestimate what cam I intended to go with in the future (if not too big) and install the springs that would go with it. That way, you will have plenty of pressures for an RR ratioi increase and no have to change them again when you get a cam. JMHO
Old Feb 14, 2008 | 06:02 PM
GreasyB's Avatar
Yea but arent springs kind of a pain to change without taking the cylinder heads off?
Old Feb 14, 2008 | 06:08 PM
henryz28's Avatar
I did my springs with the heads on in 2hrs.
Old Feb 14, 2008 | 06:36 PM
The Engineer's Avatar
With one of these Crane heads-on spring compressors, the spring change will be fast and easy.
WD
Old Feb 14, 2008 | 06:51 PM
2000GTP's Avatar
Its not too hard, and cheap insurance at that.
Old Feb 14, 2008 | 08:22 PM
ttop1986's Avatar
WD
How much are those? Does summit carry it?
EDIT: Nevermind. Is this it? http://store.summitracing.com/partde...1&autoview=sku
Old Feb 14, 2008 | 10:23 PM
Rising Phoenix's Avatar
Wow, that tool looks very handy.
Old Feb 14, 2008 | 10:27 PM
slomarao's Avatar
ya it does, pretty niffty. As for your stock springs, no dont do it.
Old Feb 15, 2008 | 12:03 AM
69gto96z's Avatar
The LT4 springs will work with a stock cam and an LT4 HC. If you plan to go bigger just buy the springs now. I have the Crane 10308 springs with my CC306, and havent had any problems.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
