1.65 Roller rocker arms
Old Oct 26, 2006 | 09:12 AM
M-MAN's Avatar
I got a set of 1.65 roller rockers from a friend. I was wonder if it would work on my LT1. They came off a Chevy SB 350. Any help is welcome.
Thanks,
Slowmaro
Old Oct 26, 2006 | 09:32 AM
Z28SORR's Avatar
Is that 1.65 or 1.6 ratio rocker? In any case if they are SA(self aligning) rockers, they will work with out any mods. If they are NSA(non-self aligning) then you will need guide plates installed and hardened push rods.
The SA rockers have flat ground washers on both sides of the roller tip that are larger diameter then the tip. These fit over the valve stem and maintain alignment.
Old Oct 26, 2006 | 10:40 AM
M-MAN's Avatar
They 1.65 roller NSA. I am going to run a .550 coil on the heads with a cam spec at .501 lift.
Nutty's96
Dec 21, 2015 06:25 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
