1.6 rrs
Old Nov 19, 2005 | 09:01 PM
LT193's Avatar
1.6 rrs
Anyone got a part number for 1.6 RRs from comp cams and anything else i would need to put em on my 1993 LT1. Thanks.
Old Nov 20, 2005 | 01:44 AM
sssalah's Avatar
Re: 1.6 rrs
Are you looking to get the self aligning or the non-self aligning rockers? do you want them with the 3/8" studs (stock) or the 7/16" studs?
You'll need to upgrade the springs and change the valve seals while you're at it.
Old Nov 20, 2005 | 11:33 AM
Bud M's Avatar
Re: 1.6 rrs
Here's what I did:
Comp Pro Mags Non SA for 7/16 studs
Comp 7/16 studs
GMPP guideplates
GM LT4 springs, retainers, and locks
Valve spring compressor from Napa (The one with the removeable **** that you can use a wrench on)
Do each cylinder at tdc so the valves can't drop very far
Tighten the rocker until the pushrod won't spin then 1/2 turn more
Old Nov 20, 2005 | 12:10 PM
simple's Avatar
Re: 1.6 rrs
i've got some Comp cams 1.6 non self aligning 3/8" pro magnum roller rockers for sale $225 shipped
have pics too
http://tinypic.com/es9jr7.jpg (everything except pushrods)
Steve
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
