1.6 RR's
Old Jun 16, 2004 | 10:58 PM
Red96Lt1's Avatar
1.6 RR's
Where do higher ratio rockers add power. Top end or low end? Also, I guessing a 15 HP increase with a full bolt on car. And what springs, hot cam springs ok?
Old Jun 17, 2004 | 03:14 AM
1racerdude's Avatar
rockers
They will increase power everywhere in the RPM range.Maybe a tad more in mid to upper RPM's.
Any quality aftermarket spring that will put 125+ on the seat and 350 or so on the nose. You didn't say what cam you have so it is hard to say.
Old Jun 17, 2004 | 07:58 AM
Red96Lt1's Avatar
Still with the stock cam.
Old Jun 17, 2004 | 01:00 PM
1racerdude's Avatar
springs
Hot cam springs will work.You don't have to change springs just to run RR.
Old Jun 17, 2004 | 01:25 PM
Red96Lt1's Avatar
Thanks, I'll probably just get the hotcam spings for insurance.
Old Jun 17, 2004 | 01:55 PM
LWillmann's Avatar
Hotcam springs with 1.6rr are barely adeqate for the Hotcam. I would recommend getting a set of springs that are good to .600, then you don't have to replace them later if you decide to install a cam.
Old Jun 17, 2004 | 02:52 PM
WS6T3RROR's Avatar
if you're going to stay with the stock cam for a long while you might consider something better than the lt4 springs. maybe step up to the stronger beehive springs offered from comp. that'll lighten up your valve train and help valve control. they probably wont hold a very big aftermarket cam though. i dont know what you have planned but if you plan on staying stock cam it might be a way to go, but of course it costs more than the lt4 springs do by far.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
