1.6 RR install question
Old Jul 14, 2004 | 11:36 AM
slayer6x6's Avatar
Im thinking about doing 1.6 rockers on my car. My question is that is this a difficult intalation? I would imagine you would have to lower the sub frame to get the valve covers off. Could someone give me a general overview of this process. Also, would I have to do anything elese to the valve train like springs, pushrods, etc?
Old Jul 14, 2004 | 11:41 AM
LWillmann's Avatar
Running a search will yield TONS of responses to this very question, but I'll try to help some...
You don't have to drop the engine or sub frame to get the valve covers off the car, they come out easily.
You'll need the rockers, hardened pushrods (if you don't already have them as some F-bodies came with them), new valve springs that will handle the lift you're going to run.. I would recomment a spring good to .600 lift, that should cover you for most cams on the market. With the springs, you'll need spring seats, retainers, locks, and while you're there you might as well replace the valve seals too.
Tools required will include a valve spring compressor, various sockets, pliers (I assume), compressed air will help (with the fittings to thread into the head to hold the valves up), a valve spring installed height tool also.
Old Jul 14, 2004 | 11:55 AM
slayer6x6's Avatar
Wow, thats more involved than I thought. Thanks for the reply.
Old Jul 14, 2004 | 12:00 PM
BUBBA's Avatar
Doubt that you will need hardened rods unless you are getting non-self aligning rockers.JMHO
Old Jul 14, 2004 | 12:04 PM
truedualws6's Avatar
If you choose to go with non-self aligning rockers remember to
use the GMPP guideplates. This has also been discussed extensively.
PN 14011051
The description says "14011051 Pushrod Guideplate
This hardened steel guideplate is used with aluminum Bow Tie
V6/90º cylinder heads with screw-in rocker arm studs." But these
are the correct guideplates for the LT1.
Old Jul 14, 2004 | 12:34 PM
grygst76's Avatar
If your putting them on a stock car meaning no internal work done, you will not need new springs and things. It is recommended to use new pushrods though but not a true necessity.
Old Jul 14, 2004 | 12:56 PM
LWillmann's Avatar
I didn't realize the stock springs would handle the added lift of the 1.6 rockers on the stock cam.
Old Jul 14, 2004 | 01:04 PM
grygst76's Avatar
I did it and had no problems at all.
Old Jul 14, 2004 | 01:59 PM
It is a chance most people don't want to take. Better to upgrade than suffer any consequences later. IMO, I would not want to put more stress on old springs.
Old Jul 14, 2004 | 02:30 PM
grygst76's Avatar
that in itself is true; each person's motor has been subjected to it's own type of abuse, If you are unsure of the condition of your motor, then disregard my post. I was well aware of the condition of mine since I knew the first owner and the very miniscual increment in lift made my decision easier to live with.
Old Jul 14, 2004 | 08:30 PM
stereomandan's Avatar
I would recommend at least getting the LT4 springs, retainers, and seats.(about $56 total) That way you can rev a little higher without worry of valve float from weak stock springs and 1.6 RR's
Dan
Old Jul 15, 2004 | 10:47 AM
I definately recommend the LT4 springs as a minimum. If you have
a GM connection you can get them for $35. Why take a chance.
Old Jul 15, 2004 | 10:54 AM
teke184's Avatar
you should be able to reuse all the seats and locks though right?
Old Jul 15, 2004 | 01:43 PM
If your budget is real tight you can just replace the springs with
the LT4s. The retainers, locks and seats are reasonably priced if
you want to change them. The stock seats are fine. The LT4
retainers may be a little lighter than the stockers. If you decide
to change the seats you will have to remove the valve stem seals
and should probably replace them too. It all depends on your
budget.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
thenewkid
Nov 27, 2014 09:41 AM
Wilson
Jul 21, 2002 05:08 PM
