1.6 Roller Rockers ... notchy
Old Dec 23, 2007 | 11:06 PM
Wild1's Avatar
I'm in the process of a head & cam swap. While pulling off my 1.6 RRs Pro Comps, the roller on the tip seems a bit notchy. They don't roll smooth like the trunion but feel like they have a slight "burr" or something that is in the rolling mechanism.
Is this normal after 10K of use? Normal street driving, no dragstrip action.
This was with a stock engine, cam, and heads.
Old Dec 25, 2007 | 07:20 PM
DustinMcGowan's Avatar
If there is a burr then take a fine gret sand paper and give it a little touch up. If the problem happens agian then you might wont to replace them. To much sanding will make them too small. If you start hearing a shattering sound make sure not to run anymore untill problem is solved. Anymore questions just ask. I have had this problem before, and it takes a little work to fix.
Old Dec 25, 2007 | 07:34 PM
wrd1972's Avatar
Mine cam off with the same miles and they turned silky smooth. Does not sound good.
Old Dec 25, 2007 | 07:48 PM
Stl94LT1's Avatar
I would send the rockers back to Comp for inspection/repair.
Old Dec 26, 2007 | 07:52 AM
aboatguy's Avatar
Somethings wrong, do the rest of your rockers feel notchy ?
Old Dec 26, 2007 | 11:36 AM
Wild1's Avatar
Yes, on the roller tip. No flat spots yet. The spinning action feels like there a bearing is hanging up... when I spin them, there is a "notch" at every revolution in the same spot.
Nutty's96
Dec 21, 2015 06:25 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
