1.6 rocker question
Old Mar 6, 2004 | 08:30 AM
TenaciousZ's Avatar
1.6 rocker question
I have a set of lt4 1.6 rockers, just the rockers, no studs etc. I'm going to be doing a head swap in a couple of weeks and was wondering If I could use the studs that are on my stock heads? and what else do I need to install the rockers.
Old Mar 6, 2004 | 10:14 AM
T/A#4's Avatar
Your LT1 studs will work but you might want to go to 7/16 ones over the OEM 3/8 studs. Also you MUST replace the valve springs or the LT1 springs will bind & break. With your stock cam you can go to the LT4 springs which are cheap & solve the binding problem.
Old Mar 6, 2004 | 07:02 PM
TenaciousZ's Avatar
way ahead of ya on the springs , my current heads have the lt4 springs while i'm swapping for a set of ported heads with beefier springs. I just didn't know If I could use the stock rocker studs with the 1.6 roller rockers that I have.
Old Mar 6, 2004 | 07:20 PM
Transamdriver's Avatar
Yep.
Old Mar 7, 2004 | 04:30 AM
craigffb's Avatar
Actually there are two different types of LT4 1.6 rr. One works with the 3/8 studs and the others need the 7/16s. I guess you'll have to check them to see which ones you have.
Old Mar 7, 2004 | 08:58 AM
TenaciousZ's Avatar
any way to tell just by looking at the rockers themselves?
Old Mar 7, 2004 | 12:29 PM
craigffb's Avatar
Not sure. I have the 3/8s rockers on my car, but I ordered them so I wouldn't have to change the stud. If they have a part number stamped on them the 3/8 rockers are part # 12370839.
Old Mar 7, 2004 | 12:35 PM
TenaciousZ's Avatar
no part number
Old Mar 8, 2004 | 11:03 AM
Bud M's Avatar
You can check the rocker's stud size by taking one to the hardware store and trying to fit a 7/16" bolt through it. But I have never heard of an LT4 rocker that took 7/16" studs.
Old Mar 8, 2004 | 01:21 PM
TenaciousZ's Avatar
thanks they do fit perfectly on a set of stock studs that I have so I guess it's safe to assume these rockers use 3/8 studs
Old Mar 8, 2004 | 01:42 PM
Mtrhds94Z's Avatar
'Real' LT4 RR's have a shouldered 7/16" stud, and use a 10mm nut..[real being factory on an LT4 motor, NOT 'lt4 heads' from factory for 'conversions' those come with LT1 [3/8"]studs..]
I guess the real Q here is did they come OFF an LT4?
Old Mar 8, 2004 | 02:03 PM
TenaciousZ's Avatar
All I know is that the rockers in question came in the lt4 hotcam kit
Old Mar 8, 2004 | 03:43 PM
Mtrhds94Z's Avatar
Those from the 'hotcam' kit would be for 3/8" then... and will fit standard LT1 studs..
Red_94Formula
Jan 22, 2015 12:17 AM
rje
Sep 9, 2002 12:35 PM
JH3204
Sep 2, 2002 01:45 AM
FormulaV8
Sep 1, 2002 03:44 PM
KASR_Z28
Aug 6, 2002 03:34 PM
