1.6 rocker install
Old Mar 23, 2009 | 06:12 PM
Red96Lt1's Avatar
1.6 rocker install
Question about setting the valve lash. So I'm ok on setting the lash on stamped rockers, but it seems on the pro mags that the spring doesn't compress nearly at all. I'm changing them on the car and i've got my compressor set at 80 psi so it forces the piston to BDC. When I tighten the polylocks, as soon I felt it compress the spring (less than 1/8th turn) the valve moves because I hear compressed air moving through the valve. So essentially I have zero lash. Any ideas?
Old Mar 24, 2009 | 02:58 AM
krillformula's Avatar
Hmm I dont really understand your question.. You dont have to use compressed air when setting the lash, and the piston should be at TDC when setting the lash.
Old Mar 24, 2009 | 08:19 AM
Red96Lt1's Avatar
I'm installing rockers. When setting the lash on the stamped rockers it seems the spring compresses a little before the lash gets set. On the pro mags, as soon as the I feel tension on the rocker, it starts to open the valve and I have essentially no lash. Is this normal?
Old Mar 24, 2009 | 09:14 AM
I have no idea why you are using compressed air for this, but if it is forcing the piston down, it is going to throw off where you want the cam lobe to be when adjusting. Sounds like you are not on the base lobe of the cam when you are trying to adjust the valve. Go to my Tech Page and use one of the adjusting methods listed.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
Red_94Formula
Jan 22, 2015 12:17 AM
KASR_Z28
Aug 6, 2002 03:34 PM
