1.6 pro form full roller rocker ?
Old Jul 23, 2008 | 10:13 PM
LT1CST's Avatar
While doing the finishing touches on my 385 i went to place the valve covers on. Well that didnt work becuase they dont fit. My pro form rockers are too big. Has anyone modified there valve covers to fit. or can someone recommend a good set of taller valve covers?
thanks
Chris
Old Jul 24, 2008 | 05:57 AM
Guest47904's Avatar
Guest
Pull the webs out.
Old Jul 24, 2008 | 07:57 AM
Green96Z's Avatar
Just cut the supports out. This is a common mod when going to aftermarket rockers. Try a search.
Old Jul 24, 2008 | 08:55 AM
1SlowFormula's Avatar
I run pro-for rockers, and I just pinched the bottom L portion of the support flat.
In other words, with a pair of pliers squezed the {L} into an {l} shape, and it fit fine without cutting the supports out...
Old Jul 25, 2008 | 02:26 AM
LT1CST's Avatar
Great info thanks. How about the passenger side oil breather portion of the covers. Right now i have a breather cap on it. Do i rip that out too?
That square piece looks to be vidal.
Chris
Old Jul 25, 2008 | 10:44 AM
I don't recall doing anything special to my breather baffle, I might have squeezed it a little with a pair of channel locks, but I can't remember since it was a few years ago now...
Old Jul 25, 2008 | 11:00 PM
LT1CST's Avatar
Ok ill check out this weekend. Im glad i dont have buy new covers
chris
Old Jul 26, 2008 | 02:39 PM
ACE1252's Avatar
I think this is what needs to be done.....
http://www.golenengineservice.com/ht...html#valvecmod
Old Jul 27, 2008 | 11:18 AM
Do not remove the webs completely. They are there to distribute the clamping force of the center bolts to the perimeter of the covers, to provide a good gasket seal. Pinch the webs, or trim them, but do not remove them. Dimple the baffle for the oil breather tube connection, or you will end up blowing oil out of the breather when the engine is under max load and blowby is at its highest level.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
