1.6 intake/1.7 exhaust
Re: 1.6 intake/1.7 exhaust
EXACTLY what I was going to post before I scrolled down a tad... really like some info on this. Any head or cam gurus think that the 1.6/1.7 I/E would make more power and or torque than strait 1.7's?
How can you run 1.7 on LT1. Is there any problems beside having to swap springs for more lift. What about piston clearance with stock pistons, rods, crank. What is the max lift that the stock pistons ... will permit?
depends on what cam you use with it. may be a good idea to go with composite LT4 valve covers to clearance the 1.6 and 1.7 NSA rockers.
depending on what cam you use, you may have to get shorter pushrods.
I'm running a cc306 and tall valve covers that i even had to grind the alternator to fit.i was doing the math and with the 1.5 my cam lift is .510 and .540 (what i'm running due to stock springs) 1.6 .544/I and .576/E with the 1.7 everywhere it would be .578/I and .612/E. If i would run 1.6/1.7 it would be .544/I and .612/E In my case would it help? Or is my cam already grind to compensate?
some people say the cams we're speaking of are already ground for extra exhaust scavenging, but the question is, are they ground enough or could they use some extra help?
what about 1.65 rockers?
from what I've read, increasing exhaust lift with a larger rocker ratio, doesn't add very much power, like increasing the intake lift with a bigger rocker does, and can even decrease power especially with a cam that has so much exhaust. If you already have 1.6/1.6, I would say it wouldn't be worth it to switch to 1.6/1.7, but you never know.
Originally Posted by dmoor88
I know there are many who say just go with a larger lift cam with 1.5 rockers, which makes a lot of sense, but Im still real curious...
I know what you meant. I just know the LT1 exhaust ports are 'underpowered' and could use some assistance in scavenging exhaust.
I heard where the intake is open a certain amount and if you change the exhaust to open farther than the intake, than you'd lose power, but is this proven somewhere?
The closest thing to proving this would be: http://www.amazon.com/exec/obidos/AS...469763-8731856 look in the chapter about rockers.
how about this. if the cams mentioned already have extra 'built in' exhaust scavenging, what about putting the 1.7 rockers on the intake side and 1.6 rockers on the exhaust?
That might be worth a shot. Get 8 1.7 RR's used from ebay or somewhere, test em back to back on the dyno and sell whichever rockers make less power and check for P-V issues just in case.
not a bad idea. changing rockers doesnt take that long, it would almost be worth dynoing with 1.7 on the exhaust and then 1.7 on the intake, leaving 1.6 on each opposing side.
hmm...
hmm...
