1.6 with GM847??
Old Jan 5, 2004 | 09:46 PM
Mr. T's Z's Avatar
1.6 with GM847??
I have a stock bottom end with Heads and cam. I am thinking about doing the GM 847 do I need to get 1.5's or can I use the 1.6's? Also I have the dual springs with the dampener from comp those should hold it correct??
Thanks,
Tyler
Old Jan 5, 2004 | 10:12 PM
bunker's Avatar
u should have no problem using 1.6 rockers on her with ok springs since the ramp rate is really slow.
Old Jan 5, 2004 | 10:36 PM
LPE Z convt's Avatar
Find out what the springs are rated to ( lift) and always do a piston to valve clearance check when you install a cam that big.... I put the 847 in my car last spring with 1.6 rockers and had plenty of clearance.... Good Luck
Old Jan 6, 2004 | 06:23 AM
Mr. T's Z's Avatar
THANKS!!!!!!!!!! You just made my day!!!!!!!!!!
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
