1.52's RR's
Old May 15, 2008 | 05:12 PM
IROCThisZ28ForLife's Avatar
1.52's RR's
I was cleaning my house the other day and came across some 1.52's rr's I had on my IROC (car came with them), they are the magnum series. I know theyarent the greatest but if it saves me some money right now as most of my car is staying stock (minus the bottem end, and turbo kit). Would these work on my car? I have a 94 Z28 with the 374 castings...Im getting my heads cleaned up, I thought I read somewhere I might need some stuff but when I search I found completely different things
they look like this:
Old May 15, 2008 | 08:44 PM
The Engineer's Avatar
Those are "non-self-aligning" rockers so you'll need to add guide plates.
WD
Old May 15, 2008 | 08:45 PM
ok thanks. Just wanted to make sure they worked =)
Old May 16, 2008 | 05:29 PM
http://store.summitracing.com/partde...8&autoview=sku
Are these the GP's I have to purchase? Also should I upgrade to a 7/16 stud at the same time?
Old May 16, 2008 | 08:12 PM
Stl94LT1's Avatar
You'll need a 7/16" rocker to run a 7/16" studs. Lokks like your rockers are 3/8"
94BlueBird
Aug 19, 2004 11:29 AM
chevyguy3
Jul 12, 2004 10:09 PM
ImportsRsloths
Jan 30, 2004 11:20 AM
Rodrigues
Nov 27, 2003 11:50 AM
steelheart
Aug 24, 2003 09:01 PM
