1.5 roller rocker to 1.6 roller rocker
Old May 28, 2005 | 11:26 AM
96KillaZ's Avatar
I know similar questions have been asked, but not this exact one. When I first got my car, the dumb mechanic told me to get the 1.5 roller rockers, and not to get the 1.6 ones because I would not be able to pass emissions. So I bought the 1.5 crane cams gold roller rockers. I have the comp cams xe 224. My question is, Is it worth the trouble to switch from a 1.5 to a 1.6 if I already have roller rockers on there? and what type of gains will I get?
Old May 29, 2005 | 10:04 PM
stereomandan's Avatar
Re: 1.5 roller rocker to 1.6 roller rocker
What lift are you at now? Is it .502 / .510 with the 1.5 RR's? If it is, then yes, you will gain from the 1.6 RR's and I'm going to say 10+ rwhp if you have stock heads.
You have CAI and headers right?
I have stock heads and cam, and going by my track times, I gained more than 10-15 rwhp from 1.5 rockers to 1.6 RR's.
Dan
Old May 30, 2005 | 10:26 AM
96KillaZ's Avatar
Dan
my lift is .502 .510 my springs can handle up to .575. I have every single bolt-on. including edelbrock heads which are pretty much stock heads. Did you already have the roller rockers at 1.5 then switch to 1.6 or did you have the stock rockers to begin with?
Old May 30, 2005 | 01:01 PM
I had the stock rockers.
As long as your heads support good flow at the new lift numbers, you will most certainly see gains.
Dan
13qtr
Oct 28, 2016 08:11 PM
LT14LIFE
Nov 15, 2015 06:22 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Daluchman1974
Sep 11, 2015 06:12 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
