1/4 times from tonight,.....WHY>>>
Old Aug 26, 2005 | 09:36 PM
93z383's Avatar
Angry 1/4 times from tonight,.....WHY>>>
reaction .4410..I know this sucks
60 ft 2.10 also sucks 24lbs in 315 35 17 g force kds
330 5.67
1/8 8.67
1/8 mph 82.22
1/4 13.41
1/4mph 103.00
I've seen 12.9s and 13.1's with 1/8 and 1/8 mph at or above this and they end up with 107 or 109 1/4mph. I have a 383. is the lt4 cam THAT BAD. In addition it is about 95 here and my engine temps are 210 even on the highway driving home. i also blew a header gasket....WTF. is my a/f off to make the engine run so hot. I have a a/f gauge but if bounces around so much if seems to be in the stoch range most of the time, never rich until it is WOT then only 3 green led's. Stock heads and 52 mm tb. Just installed 32lbs injectors and long tubes with a new pcm for less tune. and I was running 13.7 at 107 with that...........thoughts
Old Aug 26, 2005 | 09:42 PM
sniffin94's Avatar
Re: 1/4 times from tonight,.....WHY>>>
stock heads...............That's my first thought
Old Aug 26, 2005 | 10:43 PM
JBird33's Avatar
It isn't the cam, that cam gets people into the 12s all the time.
Old Aug 26, 2005 | 10:44 PM
redcamaroz28's Avatar
First of all, NEVER go off an A/F gauge unless it is a WB. Also, the hotcam is a very mild cam for a 383, and like mentioned above, the stock heads are holding you back alot. Your MPH seems low, I'd get a good tune and check the A/F with a WB.
Ryan
Old Aug 26, 2005 | 10:57 PM
FastZinTennessee's Avatar
You put stock heads on a 383, what do you expect? You can probably pick up .6 or .7 by getting your short time down, fixing your exhaust leak and sorting the tune out.
Old Aug 27, 2005 | 06:05 PM
RicocheT's Avatar
Looks good to me. Quickest run my buddy made with same type of setup on the motor was a 13.70 @ 104 spinning pretty much to the 1/8th mile.. I suggest getting the heads done and working on your 60 ft a little.
Old Aug 27, 2005 | 06:08 PM
buzz12586's Avatar
Get some DRs. Does wonders.
Old Aug 27, 2005 | 06:42 PM
FutureZMan's Avatar
I would be pointing at the heads, also true that cam does get people into the 12's, but is a bit mild for that set up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
