1/4 Times
Old Apr 9, 2009 | 01:53 PM
joshmullins8's Avatar
Question 1/4 Times
Im working on rebuilding my 94 A4 Z28, Im going with .030 Flat top pistons, LT4 Hot Cam Kit and a couple bolt ons, Im also planning on getting 373's, around a 2500-3000 converter, mid lenght headers and a mail order tune, what HP range and 1/4 times do you think I could be making?
I would also love to know what mods you have and what times your running.
Thanks Josh
Old Apr 9, 2009 | 05:34 PM
Maverick_997's Avatar
my guess if you got traction would be mid 12's at 108-110
Old Apr 9, 2009 | 09:37 PM
Z-RATED94's Avatar
Depending on DA I believe the mid 12s mentioned are about right. Run no less than a 2800 stall converter and make sure you buy a quality one and not a cheap piece of crap. Add a good trans cooler and shift kit too.
Try and keep the compression up as high as pump gas will allow. With the heads spend a little money, have them at least pocket ported and a good valve job. Also spend a little extra and upgrade to a better spring than what comes with the Hotcam.
There's more, but I'm sure others will chime in.
Old Apr 9, 2009 | 10:31 PM
JooneJune's Avatar
Mid 12's
With LT's, Full Boltons
Low 12's
Old Apr 9, 2009 | 11:20 PM
95ltslow's Avatar
Originally Posted by JooneJune
Mid 12's
Low 12's
What exactly would you consided full bolt ons?
Old Apr 10, 2009 | 12:44 AM
brianswimmer23's Avatar
yea mid to low 12's. depending on what you do.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
