1/4 difference from 2400 to a 3600 stall?
Old Jan 21, 2004 | 12:41 PM
MattysTA's Avatar
what do you guys think? 4 tenths maybe more?
Old Jan 21, 2004 | 12:45 PM
LilJayV10's Avatar
what type is the 2400 and what type is the 3600? If you are going with a good 3600 like a 9.5 ACT, Yank of Vig, yeah I'd say around 4 tenths.
Old Jan 21, 2004 | 12:46 PM
ABA383's Avatar
Depends on what type and brand of converter....I had a 2400-2800 LPE converter which came with the 383 package...unk who actually made it for LPE....Stepped up to a Vigilante 9.5" 3600 lockup and got 5 solid tenths...dont know what your set up is, but that was with 3.42s...no other changes made...by the way the Vig has been in car for 7 years with no complaints...
--Alan
Old Jan 21, 2004 | 01:05 PM
MattysTA's Avatar
the one i have now is the stupid slp 2400 stall. i should have went bigger in the first place but since my tranny is going it would have taken it out with it. so ill just put it in my new tranny that is waiting to be installed
Old Jan 21, 2004 | 02:07 PM
QCKZ28's Avatar
going from a "cheap" 2400 stall to a PI 3600 will be very noticeable.
do you have plans on a cam or headwork?
for a stock setup a 2800 stall is optimum.
why do want a 3600? why not a 3200?
jesse
Old Jan 21, 2004 | 02:33 PM
MattysTA's Avatar
jesse
I do have plans in the future for an all out engine buildup with heads and a cam but for now im going the all bolt on route.
i want a 3600 with a 2.0 str to work with my 3:73s to get a little softer launch but still be able to pull pretty hard at the top. the reason i want a 3600 is to get closer to my max torque range.
so im hoping to gain around 4-5 tenths from the slp to the vig convertor.
Old Jan 21, 2004 | 02:50 PM
QCKZ28's Avatar
that should be no problem, traction provided.
jesse
Old Jan 21, 2004 | 03:30 PM
rskrause's Avatar
Moderator
I really depends on the combo. A higher revving setup will gain more than a car with more low end torque.
Rich Krause
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rocknroler69
Apr 29, 2015 10:24 PM
