.040 over
Old Mar 20, 2007 | 06:16 PM
fbodyboy's Avatar
.040 over
what do you guys think about boring a lt1 block .040 over for a street motor. i know .030 is common for the street but is .040 too much.
Old Mar 20, 2007 | 07:31 PM
RAT454's Avatar
will be fine.
G
Old Mar 20, 2007 | 07:33 PM
SS RRR's Avatar
Why?
Old Mar 20, 2007 | 07:36 PM
quickSS's Avatar
.040" over only if your .030" over is worn out. If you go directly to .040" over then there is not as many rebuilds left in that motor.
Karl
Old Mar 20, 2007 | 07:54 PM
89TramsAmGTA's Avatar
I know of a couple of L98 motors running .040" over with no problems. Like was said above you should be fine.
Old Mar 20, 2007 | 08:43 PM
engineermike's Avatar
I'm at .060 over and 20 psi boost with no problems. The other guys are right, though. Bore as little as possible. I had to go .060 due to a gouged bore. Starting out with a stock block, I'd go .010 and get custom pistons if it'll clean up.
MIke
Old Mar 21, 2007 | 06:11 PM
fbodyboy's Avatar
i have a little nick in the #7 cylinder and pretty sure .040 bore will remove it. i only plan one having the motor for 3-4 years in the car before i switch it out again so as long as it last me that long i'll be fine.
Old Mar 21, 2007 | 09:51 PM
SS MPSTR's Avatar
0.040" is no issue at all. Even easy to get pistons for this bore as well.
Badmire68
Nov 18, 2003 08:25 PM
OutKast
Jul 3, 2003 11:03 AM
menlatin
Advanced Tech
Apr 20, 2003 02:59 PM
IgorT.455/406
3rd Gen / L98 Engine Tech
Mar 19, 2003 08:28 PM
DarthIROC
Sep 5, 2002 11:56 PM
