02 simulators cheap
Old May 5, 2006 | 08:23 AM
cleangene's Avatar
02 simulators cheap
hey check this out, I don't want to pay 80 or more for sensors, my son showed me this web page http://www.o2sensorsimulator.com, Now I can afford this and replace both...
Old May 5, 2006 | 11:58 AM
Re: 02 simulators cheap
Remember that you can only use simulators for rear O2s on OBD-II cars. You cannot use them for front O2s.
Old May 5, 2006 | 12:08 PM
Honda Hunter's Avatar
With that said shoebox why? I understand the conection may be different but if you did hook them up what would it read on a datalogger?
Old May 5, 2006 | 03:24 PM
Simulators are going to give a relatively static reading to satisfy the PCM. That won't be good enough for front O2s where the PCM needs split-second data to control fuel trims.
Old May 7, 2006 | 07:36 AM
Z28_95RIDE's Avatar
If you want to better understand what the O2 sensors are about, check out this moderator's page.
http://members.aol.com/InjuneerZZ/ScanMast.htm
It's worth the read. There's more than just the O2 information but the living document helped me to better appreciate the sophistication of modern engines. And Honda Hunter, I think it is you that has pointed to this page in other posts. Good good stuff.
Old May 7, 2006 | 08:54 AM
96capricemgr's Avatar
Even for the rears on a 96 I would consider simulators a waste. I would instead get the pcm reprogrammed and get the benifits of that with the money spent.
Old May 7, 2006 | 11:07 AM
Josh M.'s Avatar
Or you could make your own for $3 - just cut the pigtail off your old O² sensor, hook it up like this, and plug it in...a sim is one resistor, and one diode.
+12v----1KΩ resistor-------X--------|>|--------Ground wire.
We have 3 wire O² sensors, check your FSM for the color code. Like the pic shows, hook the positive wire to one end, then the 1000 ohm resistor, then hook your PCM signal wire where you see the "X", then you have the 1N4001 diode, then you hook up your ground wire.
Wrap the whole mess up in tape, and plug it in.
BTW - I got this info from my buddy Eric here:http://impalassforum.com/noncgi/ulti...=000645#000000
Old May 7, 2006 | 12:19 PM
94-97 F-Bodys have 4-wire sensors.
One problem that some people run into with "deleting" the rear O2 sensors from the stock PCM is the fact that you get a "system not ready" message when you plug into the ALDL connector for emissions check. Some states allow one or two of the "not readies". That may make a "sim" a better choice, depending on your specific situation.
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Aug 26, 2015 11:22 AM
Aug 24, 2015 06:41 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
detroitmuscle
Jul 31, 2015 04:21 AM
