02 sensor safe RTV isn't really 02 sensor safe
Old Jan 26, 2006 | 09:43 PM
speed_demon24's Avatar
Angry 02 sensor safe RTV isn't really 02 sensor safe
After I changed my header gaskets, and put copper RTV on the collector gaskets, that is supposed to be 02 sensor safe, my 02's were split by about 25, and my car would start to miss. So I put in my old 02's which were fine, and now the 02's are reading fine. So if you use RTV on the exhaust system, take out the 02's.
Old Jan 26, 2006 | 10:05 PM
Birdman7389's Avatar
Re: 02 sensor safe RTV isn't really 02 sensor safe
You know, I just did my intake manifold and egr with copperseal, and promptly got an 02 sensor failure code.(under 8K miles on the 02's) I just pulled the sensor, and hit it with some contact cleaner and a wire brush...works fine now.
Old Jan 27, 2006 | 07:02 AM
wrd1972's Avatar
I did the same thing with mine and got no codes. Maybe I was lucky. I wonder if the fact that I let it dry for several days helped.
Old Jan 27, 2006 | 04:03 PM
84 monte SS's Avatar
Why you used RTV on header gaskets is beyond me.....
WTF M8
Old Jan 27, 2006 | 04:44 PM
RedRyder518's Avatar
I did the same thing on my header gaskets and also got the "slow responce" code for both sides. I really think that you probably need to let it dry overnight before running the car.
HectorM52
Jul 30, 2017 11:46 AM
andrewcapps82
May 19, 2015 10:11 PM
AWYEE
Parts Wanted
May 12, 2015 06:58 PM
Fatdog2
Feb 13, 2015 08:19 PM
