Checking compression with the rockers off..
Old Jan 27, 2006 | 04:53 PM
Javier97Z28's Avatar
Moderator
I've done plenty of two stroke engine compression tests, but not an OHV engine.
My #8 cylinder bent a pushrod and now my rockers are removed and pushrods as well from that cylinder. I want to do a compression test before I tear it down for the heads/cam project.
Is it OK to run a compression check with the rockers off?
Old Jan 27, 2006 | 04:55 PM
96capricemgr's Avatar
Re: Checking compression with the rockers off..
It isn't going to show you anything. To get a compression reading you need to have the valves work.
Old Jan 27, 2006 | 05:01 PM
Moderator
Even if the valves are stuck closed huh? Hrm, that sucks.. oh well!
I guess I could move my good pushrods and rockers over to that cylinder to check.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
