02 Sensor Readings
Old Nov 14, 2005 | 07:33 PM
ChrisUlrich's Avatar
02 Sensor Readings
What kind of mv are they supposed to fluctuate from?
Both of mine are going from 420/450 - 750-820mv. At Idle... is that ok?
Old Nov 14, 2005 | 08:54 PM
turbo_Z's Avatar
Re: 02 Sensor Readings
They should fluctuate from .000 to 1.000 volts. But I think your readings are just fine.
Old Nov 14, 2005 | 11:13 PM
MentalCaseOne's Avatar
Those readings do not sound right to me. They should fluctuate from a lot lower than mid point.
Something like 30 to 800..... up and down, up and down ... etc.
Make sure your engine has been warmed up properly before you take the readings because the 02's take a couple of minutes to warm up on warm weather. I imagine they take longer in cold weather.
Marvin
Old Nov 15, 2005 | 11:27 AM
Marvin
They are definitely warm... The car was at normal operating temp and then sometime afterwards.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
