02 sensor lean???
Old Jan 20, 2005 | 10:40 PM
BigTedz28's Avatar
02 sensor lean???
my 95 z28 is having some slight problems.......studder at constant crusing speed at low rpm........it intermitently ses light comes on. then it will shut off, my fans will go off, and any of you have any ideas??????leak at the exhaust manifold or something? possibly a leak??
Old Jan 21, 2005 | 12:53 AM
Re: 02 sensor lean???
Did you have it scanned? What codes?
Old Jan 21, 2005 | 12:10 PM
BigTedz28's Avatar
code 44 o2 sensor lean........?
Old Jan 21, 2005 | 12:19 PM
That's the drivers side sensor. Something is affecting only that side of the engine. Exhaust leak before the sensor and misfires are the most common causes. Could also be an intermittent short to ground in the sensor signal wiring, or a faulty sensor.
Switch the sensors side to side. If the problem moves with the sensor, its a fualty sensor. If the problem stays on the drivers side, its one of the other causes listed above.
Old Jan 24, 2005 | 09:28 PM
BigTedz28's Avatar
intermittent ground huh?? well its odd cuz like when its at nite time and i have my lights running and radio on, all my lights will dim right before the sevice engine soon light comes on, and while its on, my bat. light will slowly drop to below 8 then back up to 12 when it shuts offf........sooo is that showing me its ground effected???? what will i have to do to check this??
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Jlo
Jul 29, 2015 03:52 PM
Noct
Jul 14, 2015 01:18 AM
