With ~500 flywheel HP, how much will stock cat-back hurt?
Too cheap to buy a catback, how much will that hurt? I'm running Jet-Hot Long Tubes, and will build a custom Y-pipe, and probably an electric cutout. But, I'm talking about with the cut-out closed...running through the exhaust.
I would say you'd be able to notice a definite sotp feel from going closed to open cut-out, especially since going to an aftermarket exhaust on a stock engine will net you some gains. I'm guesstimating, here, but based on your power levels it should be 20-30 hp? maybe more since you have headers...
Re: With ~500 flywheel HP, how much will stock cat-back hurt?
Damn this is an old thread.
I ended up getting a Magnaflow Cat-Back from I forget where for $280 shipped, just have to get a Y-Pipe now.
I did end up dyno'ing back to back runs and their was a 13rwhp difference. I do believe if I made 3 pulls each it would've been closer to a 20rwhp difference. This was when the car wasn't running right either and it only put down 378rwhp open and 365rwhp closed. I got the graph somewhere.
stockssn2o
May 25, 2015 08:54 AM
