View Poll Results: Preffered method?
Drop it out the bottom
16
50.00%
Pull it out the top
16
50.00%
Voters: 32. You may not vote on this poll
[Engine Pulling] Your preffered method? Drop bottom or out the top?
Old Apr 9, 2003 | 07:09 PM
  #16
IRABuss's Avatar
In order to use the strut tower brace, you would have to get some bolts and stick them in the holes...after you lifted the body up a little off the struts....not worth it. just use the "frame" in the front and hook some chain around it. be sure to protect the paint.
Old Apr 9, 2003 | 07:17 PM
  #17
Sergio's Avatar
Ok, so there is no chance of bending anything ?
It would be great as we have this great crane (milspec) that can go in any direction and lifting anything upto 8 tons (tested every year !) is no sweat.
The 'frame' you refer to is the where the radiator cover connects to ???
Thanks,
Sergio
Old Apr 9, 2003 | 07:22 PM
  #18
Grease's Avatar
Another vote for out through the bottom. When I did my heads and cam I dropped the entire engine/tranny/k-member out throught the bottom in about 90 minutes. An hour later I had both heads and intake off. I also didn't have to worry about dealing with my headers by doing it this way. There is so much room to work.
Its not really that bad unplugging the wiring harness from the engine and laying it over by the PCM. You don't have to remove the radiator, condensor or cooling fans. You don't need an alignment either when you are done.
The only downside is you have to disconnect both front brake lines from the ABS unit and to get those 2 out of the way you have to disconnect all other brake lines from the ABS unit. But it only takes 15 minutes to bleed the system.
If you have access to a shop lift, then this is the way to go.
Old Apr 10, 2003 | 03:40 AM
  #19
Van5150's Avatar
If you guys had to guess, how high did you have to lift the car up? You guys are getting some great times un-installing/installing the engine. It may actually seem worthwhile when doing headers/cam install.
Old Apr 10, 2003 | 01:33 PM
  #20
Grease's Avatar
I'm an auto tech so I did mine on a shop lift at work with all the airtools and shop supplies I needed. Thats why it took me such a short time. If you are going to do it at home you'll need to lift the front of your car about 3 feet off the ground to slide the engine out from underneath the car.
Old Apr 15, 2003 | 09:43 PM
  #21
Dave88LX's Avatar
Here's a few pics of mine coming out the top. Pretty damn tight!!!!!
http://paradox.shacknet.nu/dave88lx/...nock/pull1.jpg
http://paradox.shacknet.nu/dave88lx/...nock/pull2.jpg
http://paradox.shacknet.nu/dave88lx/...nock/pull3.jpg
I had the chain in the middle at first, that wasn't going to work, as teh balancer hits the AC condensor. I had to move the chain up so the engine was angled. I think a load leveler will work wonders putting this back in though!
Old Apr 15, 2003 | 10:20 PM
  #22
Grease's Avatar
Heres a few pictures of mine when I did my heads/cam, out throught the bottom. So much room and so easy I didn't know what to do
http://www.geocities.com/greasemunkeey/PhotoPage1.html
calaban
May 18, 2020 06:43 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
formula218
Dec 2, 2014 04:27 PM
