*PICTURE* Is this a polylock rockerarm?
Old Sep 17, 2003 | 07:01 PM
95BlackTA's Avatar
Sorry for crappy qual, its a phone. Are these polylock roller rockers or not? It doesnt look like the other ones ive seen in pics. Other ones look like the nut actually gets jammed in the rocker arm, and this ones it doesnt, the nut just sits in there loosely and can spin.
These are C.A.T 4340 steel 1.6 RR's.
Old Sep 17, 2003 | 08:03 PM
93Z4ME's Avatar
Those are not Poly Lock nuts but it looks like you could use polylocks in place of those nuts. Polylocks would normally be used with full roller rockers and would rest on the flat part of the roller fulcrum. You don't have roller fulcrums, only roller tips but you still have a flat area on top of the pivot ball which sits under the current "Locking" nut. The Polylocks work by screwing an integral alen screw down on top of the rocker stud which "binds" the polylock to the stud. You existing locking nut works by friction on the threads.
Old Sep 17, 2003 | 08:23 PM
95BlackTA's Avatar
Ok thank you...anyone know where to buy some polylocks? Ill check out thunderracing and summit right now.
JCSWS6
Jul 19, 2015 06:47 PM
2QUIK6
Jan 6, 2008 09:10 PM
95BlackTA
Aug 25, 2003 06:20 PM
Redbird
Nov 20, 2002 11:54 AM
