*pics of spark plug tips*.....these look ok?
Old Jun 28, 2003 | 11:36 AM
got_hp?'s Avatar
comparing to a chart i found, it seems my plugs are running ok............just need a second opinion.
plug tips
Old Jun 28, 2003 | 11:58 AM
jkipp84's Avatar
Not too bad.. clean 'em up with a wire brush, reset the gap, and you should be fine.
Buuuut - since they're out, why not get some fresh ones? NGK's or regular (not +2 or +4) Bosch platinums are only a couple bucks a pop.
Old Jun 28, 2003 | 12:10 PM
Vader's Avatar
A little hint here. Given the difficulty of removing and replacing these F-body plugs, never re-use them. Also cleaning sparkplugs is not recommended, especially if using a wire brush made from any metal. The ceramic will abrade the metal and leave deposits on the center electrode insulator, and cause all sorts of problems. Put new plugs in it. The colour is fine.
Old Jun 28, 2003 | 02:23 PM
got_hp?'s Avatar
yeah, i would never clean/reuse plugs...........just wanted to make sure everything is burning ok.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
