*pics of spark plug tips*.....these look ok?
Not too bad.. clean 'em up with a wire brush, reset the gap, and you should be fine.
Buuuut - since they're out, why not get some fresh ones? NGK's or regular (not +2 or +4) Bosch platinums are only a couple bucks a pop.
A little hint here. Given the difficulty of removing and replacing these F-body plugs, never re-use them. Also cleaning sparkplugs is not recommended, especially if using a wire brush made from any metal. The ceramic will abrade the metal and leave deposits on the center electrode insulator, and cause all sorts of problems. Put new plugs in it. The colour is fine.
