*HEAD WORK* need info on them.... ganna be doing them next week
Old Jan 29, 2004 | 11:25 PM
formula king's Avatar
okay i might have a ****ed up valve so if they are i am just gana have heads ported with new valves springs etc.........
i was wandering how much rwhp gain am i looking at with stock cam...also how much rwhp will i have with these mods
1ported heads
2.full exhaust.
3.ram air
4.underdrive pullies
5.t/b bypass
6.and new igntion(plugs wire,coil,spark plug)
7.3.73
what kind of times do most lt1 run with those mods.(with tires)
ans suspension(shocks, springs, subframe.rear strut tower brace)
Old Jan 29, 2004 | 11:26 PM
jonaddis84's Avatar
What makes you think you have a crappy valve?
And referring to headporting as "Stage 2" means nothing.
Old Jan 30, 2004 | 09:32 AM
well there was a hole in my air box going to the mass air....which causes the car to run really lean, and i been getting 140 mile a tank latley (just an idea)
Old Jan 30, 2004 | 09:34 AM
i had numbers but i forgot exactly what it was....i did remember the stage it was at the shop(they had 3 stages)
Old Jan 30, 2004 | 10:04 AM
WS Sick's Avatar
If they do a good job and get your flow in the 250 to 260 cfm range at 500 lift then you should pick up a good 25 to 35 hp.
canbaufo
May 17, 2015 10:35 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
silvermansteve
Mar 4, 2015 05:02 PM
