*ATTN* 1993 Cam Swap owners inside!!!!
Old Nov 4, 2003 | 02:17 PM
JKDZ28's Avatar
i plan on doing a cam in the next 2 months
and im wondering what kind of timing chain, etc that you used?
any suggestions/help hints are welcome!
thanks in advance!
Old Nov 4, 2003 | 02:30 PM
Fastbird93's Avatar
Well, both of my cars got the vented opti treatment. However, I can't remember who it is.....comp cams maybe, but someone has an aftermarket stronger timing set for the non-vented opti cars. Definitely a plus if you're doing a budget setup.
ps: check out the new speed density website that we just brought back to life.
Old Nov 4, 2003 | 02:33 PM
brandboZ28's Avatar
I just finsihed up a cam swap and used a new stock chain. Unless you upgrade to the 95+ timing cover, there arent many options for us. I think Lunati makes one but when I was researching it, everyone was scared to try it becuase it was new so I just went with another stocker. They say its plenty strong enough unless you are using one hoss of a cam. Good luck.
Old Nov 4, 2003 | 03:06 PM
JKDZ28's Avatar
do you have to change the timing cover?
Old Nov 4, 2003 | 03:22 PM
brandboZ28's Avatar
For the stock replacement and the Lunati, no, but for the LT-4 and the LT-4ED, you have to change the cover. You could also go with a Cloyes dual roller but then youre gonna need an electric water pump and all of that jazz. These are all of the reasons I stuck with the stock.
Old Nov 4, 2003 | 04:05 PM
JKDZ28's Avatar
so if i get a CSI electric WP i can run the cloyes double roller?
w/o changing the timing cover?
is there anything else i must change over???
Old Nov 4, 2003 | 04:27 PM
faded93bird's Avatar
you would have to change to a 95+ cover and vented opti as well,to run the cloyes
I just went with a stocker and keept my non-vented opti
Old Nov 4, 2003 | 06:56 PM
12SCNDZ's Avatar
New factory '93 replacement with non vented opti.
Frank
Old Nov 4, 2003 | 09:18 PM
JKDZ28's Avatar
so lets say i went with the stock timing chain....
would it hold up to lets say a cam the size of a 230/236 XE cam??
or would i need a better one?
Old Nov 5, 2003 | 09:41 PM
JKDZ28's Avatar
anyone???
Old Nov 6, 2003 | 12:38 AM
Formula_one's Avatar
I converted to the 95+ opti... TC cover wasnt very much... Converting costs about the same as buying the non-vented... Though I got my parts at cost.. I'm sure you could do the same though. I converted to a CSI pump and regret it. My car runs hot. Though I havent driven it for 3 1/2 months... I would stay with the stock WP if I were you.
What cam are you going with?
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
Sarahrope64
Nov 27, 2014 11:17 AM
chuyz28
Nov 25, 2014 11:14 PM
